I know about NTP, but since it's communication is NOT encrypted I don't want to use it.
The question is, how can I sync time with Tor proxy?
"HTP" protocol can achieve this, but it's not reliable(sometimes timeout due to Tor slowness).
How can I get reliable time from Tor's nodes quickly, anonymously, and correctly?
Jill
  • 31
  • I'm using Windows, so Linux is no-go. Any chance to get tlsget.exe(Windows) or other thing? Also I already read about Tails... –  Oct 22 '14 at 14:42
Have a look at how Tails does time syncing via the Tor consensus file. You can also use Jacob Applebaum's tlsdate over Tor.
sroecker
  • 131
Really, if you're that paranoid that you won't even trust your network provider not to man-in-the-middle attack NTP traffic, then you may as well invest in a cheap GPS receiver.
Then once you've got a cheap GPS receiver, configure ntpd to use that to synchronise the time instead. GPS provides a very accurate time-source.
Of course someone could spoof GPS satellites, but then everyone in the area would be constantly getting lost when their navigation devices failed.
