I have college wifi when I use Skype it gets connected and after some time gets disconnected. This happen repeatedly.
I want to know Can I use Tor to avoid this problem ? I am not sure but may be Tor fix the disconnection problem.
A. Prasad
  • 273
6 Answers6
You might get Skype working on your machine. However the usage of Skype with Tor is highly discouraged. I quote from Tor's wiki:
Skype is closed source and users have no control over the encryption keys used. Skype can therefore decrypt and monitor communications arbitrarily. It is unwise to communicate in an unsafe manner over Tor. Skype also collects a large amount of personal data and reports back to a central server.
Furthermore it is often reported that Skype blocks Tor exit relays. So you might encounter the same problems you already have.
Jens Kubieziel
  • 8,630
  • 35
  • 116
You can use Skype with Tor, but your connection quality might suffer because of the low connection speed. It may make your problem worse.
The college network is probably not intentionally breaking Skype. More likely it is just generally unreliable. If your Skype issues are caused by confused routers, dodgy access points and resetting NAT session tables, then Tor is not going to help with that.
Jobiwan
  • 3,685
  • 19
  • 31
Install tails OS and add skype to your programs. Have not done this myself but it sounds like it should work.
bob smith
  • 19
have a look at this paper (A Tor-Based Anonymous Communication Approach to Secure Smart Home Appliances) in the section "Testing with Voice-over-Internet Protocol Applications", there is an experiment with Skype over Tor. What I figured out from their results is that Skype can work via Tor, but not smoothly for the time being due to the Time-to-Live of UDP.
2523fewqf23f
  • 545
In my experience, using an application like Skype over Tor would defeat the purpose of Tor and perhaps even compromise the security and anonymity of the Tor relays due to the nature of the Skype network as well as the tremendous amount of meta-data collected by Skype. With this information, a malicious attacker or state sponsored spying and wiretapping efforts could uncover enough of the Tor network to render it's overall purpose useless. In short, please do not use Skype or other social networking/communication apps over Tor as you may compromise the security of everyone who depends on Tor in the process.
