Is there a way to specify a bridge while starting Tor, from command line? I'm working on a script that runs multiple instances of Tor and I find it easier to add the bridge (all the instances are going to use the same bridge) on the command that runs the instance itself, instead of editing the torrc file after.
Thank you all in advance
Ali Torabi
  • 93
Alekos Filini
  • 161
You can write the information into some files, say bridge.1, bridge.2 etc. Inside the file are lines with bridges like
Bridge 127.0.0.1:4567 0123456789ABCDEF
Besides this bridge files you should also have a torrc file all other settings. Now you can start the Tor software with a line like
tor --defaults-torrc torrc -f bridge.1
The first option takes your default torrc as argument and is always the same. The second option contains the file with bridge information. You can vary this file depending which bridges you want to use.
Jens Kubieziel
  • 8,630
  • 35
  • 116
