I'm using Whonix Gateway and Workstation. I can request a new tor circuit in the Gateway via arm, I press "n". How can I do this in the Workstation terminal?
Do once. (Install missing dependencies. Only required for Whonix 8. Will be no longer required on Whonix 9.)
sudo apt-get update
sudo apt-get install telnet
Do every time you want a new circuit. Run tor-ctrl (installed by default) with signal newnym.
bash -x tor-ctrl -p notrequired -c "signal newnym"
If you see at the bottom of the output.
+ sendcmd signal newnym
+ echo signal newnym
+ sleep 1
+ sendcmd QUIT
+ echo QUIT
+ sleep 1
+ STR='Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '\''^]'\''.
250 OK
250 OK'
+ vecho 'Trying 127.0.0.1...
250 OK
250 OK'
+ '[' 0 -ge 1 ']'
+ echo 'Trying 127.0.0.1...
250 OK
250 OK'
++ grep -c '^250 '
+ '[' 2 = 3 ']'
+ exit 1
Then it succeeded. (exit 1 is a bug in tor-ctrl, because it doesn't understand the double 250 OK.)
Full disclosure:
I am a maintainer of Whonix.
- 2,847
- 2
- 20
- 35
