Is there any way I can see what each file does in Tor source code? A simple file with a list for example?I do not want to read and surf through whole code.
Gitweb allows you to browse through the code. Especially the src/or directory has relevant source code. Some of the files contain a description what this file does:
* \file directory.c
* \brief Code to send and fetch directories and router
* descriptors via HTTP. Directories use dirserv.c to generate the
* results; clients use routers.c to parse them.
This belongs tosrc/or/directory.c.
- 8,630
- 5
- 35
- 116
Yes, this way, for example:
(sorry, do not know how to hide it)
[tor-2ee56e4/contrib/id_to_fp.c]
Helper for directory authority ops. When somebody sends us a private key, this utility converts the private key into a fingerprint so you can de-list that fingerprint
[tor-2ee56e4/src/ext/strlcat.c]
Appends src to string dst of size siz
[tor-2ee56e4/src/ext/strlcpy.c]
Copy src to string dst of size siz
[tor-2ee56e4/src/ext/eventdns.c]
Async DNS Library
[tor-2ee56e4/src/ext/tinytest_demo.c]
Welcome to the example file for tinytest
[tor-2ee56e4/src/ext/tinytest.c]
tinytest.c
[tor-2ee56e4/src/ext/curve25519_donna/curve25519-donna-c64.c]
Curve25519 elliptic curve, public key function
[tor-2ee56e4/src/ext/curve25519_donna/curve25519-donna.c]
[tor-2ee56e4/src/ext/OpenBSD_malloc_Linux.c]
malloc.c
[tor-2ee56e4/src/common/crypto_format.c]
Formatting and parsing code for crypto-related data structures
[tor-2ee56e4/src/common/crypto_curve25519.c]
Wrapper code for a curve25519 implementation
[tor-2ee56e4/src/common/log.c]
Functions to send messages to log files or the console
[tor-2ee56e4/src/common/util_codedigest.c]
Return a string describing the digest of the source files in src/common/
[tor-2ee56e4/src/common/procmon.c]
Process-termination monitor functions
[tor-2ee56e4/src/common/container.c]
Implements a smartlist (a resizable array) along with helper functions to use smartlists. Also includes hash table implementations of a string-to-void* map, and of a digest-to-void* map
[tor-2ee56e4/src/common/di_ops.c]
Functions for data-independent operations
[tor-2ee56e4/src/common/compat_libevent.c]
Wrappers to handle porting between different versions of libevent
[tor-2ee56e4/src/common/memarea.c]
Implementation for memarea_t, an allocator for allocating lots of small objects that will be freed all at once
[tor-2ee56e4/src/common/crypto.c]
Wrapper functions to present a consistent interface to public-key and symmetric cryptography operations from OpenSSL
[tor-2ee56e4/src/common/tortls.c]
Wrapper functions to present a consistent interface to TLS, SSL, and X.509 functions from OpenSSL
[tor-2ee56e4/src/common/address.c]
Functions to use and manipulate the tor_addr_t structure
[tor-2ee56e4/src/common/torgzip.c]
A simple in-memory gzip implementation
[tor-2ee56e4/src/common/aes.c]
Implements a counter-mode stream cipher on top of AES
[tor-2ee56e4/src/common/mempool.c]
This is an implementation of memory pools for Tor cells
[tor-2ee56e4/src/common/util.c]
Common functions for strings, IO, network, data structures, process control
[tor-2ee56e4/src/common/compat.c]
Wrappers to make calls more portable
[tor-2ee56e4/src/test/test_config.c]
test_config.c
[tor-2ee56e4/src/test/test_containers.c]
test_containers.c
[tor-2ee56e4/src/test/test_introduce.c]
test_introduce.c
[tor-2ee56e4/src/test/test.c]
Unit tests for many pieces of the lower level Tor modules
[tor-2ee56e4/src/test/test_util.c]
test_util.c
[tor-2ee56e4/src/test/test_dir.c]
test_dir.c
[tor-2ee56e4/src/test/bench.c]
Benchmarks for lower level Tor modules
[tor-2ee56e4/src/test/test_ntor_cl.c]
test_ntor_cl.c
[tor-2ee56e4/src/test/test_microdesc.c]
test_microdesc.c
[tor-2ee56e4/src/test/test_crypto.c]
test_crypto.c
[tor-2ee56e4/src/test/test_addr.c]
test_addr.c
[tor-2ee56e4/src/test/test_cell_formats.c]
test_cell_formats.c
[tor-2ee56e4/src/test/test_replay.c]
test_replay.c
[tor-2ee56e4/src/test/test_data.c]
test_data.c
[tor-2ee56e4/src/test/test-child.c]
Trivial test program which prints out its command line arguments
[tor-2ee56e4/src/test/test_pt.c]
test_pt.c
[tor-2ee56e4/src/or/networkstatus.c]
Functions and structures for handling network status documents as a client or cache
[tor-2ee56e4/src/or/dns.c]
Implements a local cache for DNS results for Tor servers
[tor-2ee56e4/src/or/rendcommon.c]
Rendezvous implementation: shared code between introducers, services, clients, and rendezvous points
[tor-2ee56e4/src/or/config.c]
Code to parse and interpret configuration files
[tor-2ee56e4/src/or/replaycache.c]
Self-scrubbing replay cache for rendservice.c
[tor-2ee56e4/src/or/command.c]
Functions for processing incoming cells
[tor-2ee56e4/src/or/transports.c]
Pluggable Transports related code
[tor-2ee56e4/src/or/connection_or.c]
Functions to handle OR connections, TLS handshaking, and cells on the network
[tor-2ee56e4/src/or/status.c]
Keep status information and log the heartbeat messages
[tor-2ee56e4/src/or/circuitbuild.c]
The actual details of building circuits
[tor-2ee56e4/src/or/circuitlist.c]
Manage the global circuit list
[tor-2ee56e4/src/or/routerset.c]
A routerset specifies constraints on a set of possible routerinfos
[tor-2ee56e4/src/or/confparse.c]
Functions to parse config options
[tor-2ee56e4/src/or/addressmap.c]
A client-side struct to remember requests to rewrite addresses to new addresses
[tor-2ee56e4/src/or/nodelist.c]
A list of all the nodes
[tor-2ee56e4/src/or/circuitmux.c]
Circuit mux/cell selection abstraction
[tor-2ee56e4/src/or/rendmid.c]
Implement introductions points and rendezvous points
[tor-2ee56e4/src/or/config_codedigest.c]
Return a string describing the digest of the source files in src/or/
[tor-2ee56e4/src/or/statefile.c]
statefile.c
[tor-2ee56e4/src/or/routerparse.c]
Code to parse and validate router descriptors and directories
[tor-2ee56e4/src/or/dirserv.c]
Directory server core implementation
[tor-2ee56e4/src/or/connection_edge.c]
Handle edge streams
[tor-2ee56e4/src/or/dnsserv.c]
Implements client-side DNS proxy server code
[tor-2ee56e4/src/or/onion_tap.c]
Functions to implement the original Tor circuit extension handshake
[tor-2ee56e4/src/or/buffers.c]
Implements a generic interface buffer
[tor-2ee56e4/src/or/rendclient.c]
Client code to access location-hidden services
[tor-2ee56e4/src/or/ntmain.c]
ntmain.c
[tor-2ee56e4/src/or/onion_ntor.c]
onion_ntor.c
[tor-2ee56e4/src/or/relay.c]
Handle relay cell encryption/decryption, plus packaging and receiving from circuits, plus queuing on circuits
[tor-2ee56e4/src/or/fp_pair.c]
fp_pair.c
[tor-2ee56e4/src/or/hibernate.c]
Functions to close listeners, stop allowing new circuits, etc
[tor-2ee56e4/src/or/circuituse.c]
Launch the right sort of circuits and attach streams to them
[tor-2ee56e4/src/or/entrynodes.c]
Code to manage our fixed first nodes for various functions
[tor-2ee56e4/src/or/router.c]
OR functionality, including key maintenance, generating and uploading server descriptors, retrying OR connections
[tor-2ee56e4/src/or/connection.c]
General high-level functions to handle reading and writing on connections
[tor-2ee56e4/src/or/reasons.c]
Convert circuit, stream, and orconn error reasons to and/or from strings and errno values
[tor-2ee56e4/src/or/microdesc.c]
microdesc.c
[tor-2ee56e4/src/or/tor_main.c]
Stub module containing a main() function. Allows unit test binary to link against main.c
[tor-2ee56e4/src/or/main.c]
Toplevel module. Handles signals, multiplexes between connections, implements main loop, and drives scheduled events
[tor-2ee56e4/src/or/circuitmux_ewma.c]
EWMA circuit selection as a circuitmux_t policy
[tor-2ee56e4/src/or/policies.c]
Code to parse and use address policies and exit policies
[tor-2ee56e4/src/or/cpuworker.c]
Implements a farm of 'CPU worker' processes to perform CPU-intensive tasks in another thread or process, to not interrupt the main thread
[tor-2ee56e4/src/or/directory.c]
Code to send and fetch directories and router descriptors via HTTP
[tor-2ee56e4/src/or/control.c]
Implementation for Tor's control-socket interface
[tor-2ee56e4/src/or/onion_fast.c]
Functions implement the CREATE_FAST circuit handshake
[tor-2ee56e4/src/or/channeltls.c]
channel_t concrete subclass using or_connection_t
[tor-2ee56e4/src/or/rendservice.c]
The hidden-service side of rendezvous functionality
[tor-2ee56e4/src/or/dirvote.c]
Functions to compute directory consensus, and schedule voting
[tor-2ee56e4/src/or/onion.c]
Functions to queue create cells, wrap the various onionskin types, and parse and create the CREATE cell and its allies
[tor-2ee56e4/src/or/circuitstats.c]
Global list of circuit build times
[tor-2ee56e4/src/or/geoip.c]
Functions related to maintaining an IP-to-country database
[tor-2ee56e4/src/or/channel.c]
OR-to-OR channel abstraction layer
[tor-2ee56e4/src/or/routerlist.c]
Code to maintain and access the global list of routerinfos for known servers
[tor-2ee56e4/src/or/rephist.c]
Basic history and "reputation" functionality to remember which servers have worked in the past, how much bandwidth we've been using, which ports we tend to want, and so on
[tor-2ee56e4/src/tools/tor-gencert.c]
tor-gencert.c
[tor-2ee56e4/src/tools/tor-fw-helper/tor-fw-helper.c]
The main wrapper around our firewall helper logic
[tor-2ee56e4/src/tools/tor-fw-helper/tor-fw-helper-upnp.c]
The implementation of our UPnP firewall helper
[tor-2ee56e4/src/tools/tor-fw-helper/tor-fw-helper-natpmp.c]
The implementation of our NAT-PMP firewall helper
[tor-2ee56e4/src/tools/tor-resolve.c]
tor-resolve.c
[tor-2ee56e4/src/tools/tor-checkkey.c]
tor-checkkey.c
But there might be stuff that you must read from source code files.
