This question is an extension of How does Tor handle DNS poisoning.
After having read Introducing DNS Resolver for Tor and DNS security issues, I am a bit concerned about the riscs of using Tor (Browser) in presence of DNS spoofing/poisoning or MITM attacks.
If I have understood correctly, following happens when visiting https://example.com:
  1. Tor exit node resolves example.com to an IP, e.g. 5.5.5.5
  2. End-to-end HTTPS encryption is established between Tor browser client and example.com.
Given an evil exit node resolves the domain name to a different IP address 5.5.5.7 owned by Mallory. Then the returned site still needs to deliver a certificate as response, which most probably is self-signed and not trusted by a browser root certificate authority. Hence I would get a certificate error in case of DNS spoofing.
Doesn't that mean, I am safe concerning DNS attacks, when enforcing HTTPS with Tor?
cane_xmx3
  • 15
Yes. You are.
I would also like to point out that your normal DNS server could perform this too, however targeted at you specifically. The Tor exit node does not know who is trying to access the website, just someone.
I would also like to point that you may want to use onion services wherever possible as they do not have this problem.
HackerNCoder
  • 336
