Is it useful to run the Whonix gateway in a VM inside of tails, running as a liveboot, to connect to another VM like for example Kali, which also runs inside of Tails, because it would rout my traffic through tor 2 times and I still could setup a VPN in Kali so I would not face the disadvantage of blacklisted exit nodes or are there any other possible issues I do not recognize? Because I have read it would be kinda dangerous to use Tor over Tor but no one was able to exactly explain why. Thanks for any help or explanations
Asked
Active
Viewed 2,088 times
1https://www.whonix.org/wiki/DoNot#Prevent_Tor_over_Tor_Scenarios – adrelanos Jul 13 '19 at 16:56
Ok I understand that it's easier to identify someone who uses more than 3 hopes in a row but what if I add another VPN so the setup would be Tor>VPN>Tor>VPN nobody (except the provider of the first VPN) would notice that my traffic is routed through 2 times am I right? And I still don't exactly understand why it's possible dangerous to get the same node 2 times – Warlord456 Jul 13 '19 at 18:12
1related: https://www.whonix.org/wiki/Warning#Confirmation_Attacks - It might result in using the same Tor relay as both Tor entry guard and Tor exit relay. Path selection is best left to Tor - unless being more clever than Tor. On VPNs see also: https://www.whonix.org/wiki/Tunnels/Introduction – adrelanos Jul 19 '19 at 12:48
- Tor-over-Tor should always be avoided: https://tor.stackexchange.com/a/11922/5234 || 2) a VPN has nothing to do with anonymity: https://tor.stackexchange.com/a/20033/5234
– DJCrashdummy Sep 01 '19 at 11:52
