I am trying to use tor for anonymous access through privoxy as a proxy through urllib2.
System info: Ubuntu 14.04, recently upgraded from 13.10 through dist-upgrade.
This is a piece of code I am using for test purposes:
import urllib2
def req(url):
proxy_support = urllib2.ProxyHandler({"http": "127.0.0.1:8118"})
opener = urllib2.build_opener(proxy_support)
opener.addheaders = [('User-agent', 'Mozilla/5.0')]
return opener.open(url).read()
print req('https://check.torproject.org')
The above outputs a page with a sorry, but you don't use Tor message.
As for my configurations: /etc/tor/torrc
ControlPort 9051
## If you enable the controlport, be sure to enable one of these
## authentication methods, to prevent attackers from accessing it.
#HashedControlPassword 16:872860B76453A77D60CA2BB8C1A7042072093276A3D701AD684053EC4C
HashedControlPassword 16:B3B0BA631D41D6FE601488FC7A9A2E80AB7815580C1C78F2865F30F63B
/etc/privoxy/config
forward-socks5 / localhost:9050 .
$ sudo netstat -ntap | grep tor outputs:
tcp 0 0 127.0.0.1:9050 0.0.0.0:* LISTEN 1045/tor
tcp 0 0 127.0.0.1:9051 0.0.0.0:* LISTEN 1045/tor
tcp 0 0 10.0.0.94:56736 85.17.190.83:9002 ESTABLISHED 1045/tor
tcp 0 0 10.0.0.94:60558 50.7.110.118:9001 ESTABLISHED 1045/tor
tcp 0 0 10.0.0.94:43206 62.210.236.135:443 ESTABLISHED 1045/tor
$ sudo netstat -ntap | grep privoxy outputs:
tcp 0 0 127.0.0.1:8118 0.0.0.0:* LISTEN 887/privoxy
And yet, all requests are received at the server with my actual IP
