Cookies don't show up in Privacy & Security Preferences when you click Manage Data (it shows no cookies even when there are cookies), which appears to be inherited from Firefox's Private Browsing mode.
As a temporary fix I tried using the extension cookies.txt, but that didn't work for me, clicking it does nothing.
I tried running its source code directly (GitHub) in Web Developer > Scratchpad, but this didn't work either.
function saveCookies(cookies) {
  var header = [
    '# Netscape HTTP Cookie File\n',
    '# https://curl.haxx.se/rfc/cookie_spec.html\n',
    '# This is a generated file! Do not edit.\n\n'
  var body = cookies.map(formatCookie)
  var blob = new Blob(header.concat(body), {type: 'text/plain'});
  var objectURL = URL.createObjectURL(blob);
  browser.downloads.download({url: objectURL, filename: 'cookies.txt',
    saveAs: true, conflictAction: 'overwrite'});
function handleClick() {
  var gettingAll = browser.cookies.getAll({});
  gettingAll.then(saveCookies);
handleClick()
It gave this exception, but this could be my fault since I don't know what I'm doing.
Exception: ReferenceError: browser is not defined
handleClick@Scratchpad/1:24:7
@Scratchpad/1:28:1
I also tried looking inside the file Browser/TorBrowser/Data/Browser/profile.default/cookies.sqlite while the broswer was open, but the moz_cookies column appeared to be empty.
Is there some way to export the cookies from the Tor Browser Bundle or even view them at all?
Mark
  • 61
You can control cookie preferences from about:config.
Maybe this link will help: About Config Preferences
Mir Saman
  • 368
  • 13
This is not the best solution since it requires you to install an add-on, but it works at least. The Cookies Manager does let you see and import/export your cookies.
Sturn
