NoScript resetting to default after closing Tor Browser
NoScript default is enabling script, object, media, frame, font, webgl, fetch, other!!
I can manually go to extension page and reset to true default settings which is frame, fetch, other.
When close and open Tor Browser, NoScript defaults back to script, object, media, frame, font, webgl, fetch, other!!
How to have NoScript save settings between launch of Tor Browser?
Some other info:
  • upgraded from 7.x to 8.0.1
  • using linux
palswim
  • 113
pnujhpdo
  • 103
This is a known issue: https://trac.torproject.org/projects/tor/ticket/27175
Looks like the fix will be released very soon with the next update.
Andy Eoch
  • 46
Since NoScript 10.2.2 you can check NoScript Options>Advanced>Override Tor Browser's Security Level preset. Also Notice that in Tor Browser 9 NoScript's and HTTPS Everywere's toolbar buttons are hidden in order to further emphasize the Security Level UI: if you need to fine tune the underlying extensions you'll probably want to bring those buttons back from the Customize menu item.
You can change the Tor Browser Security Settings Security Level to Safest, which only enables frame and other by default.
Unfortunately, as of Tor Browser 8.0.4, it looks like I can't save per-site permissions across sessions, even with the new extensions.torbutton.noscript_persist setting.
palswim
  • 113
