I'm having some major problems with my hidden services. I have about 10 sites hosted on my Pi. All of them are very low traffic sites (Maybe about 5-10 visits a day)
Only 2-4 sites are working out of those 10 most of the time even though they are set up the same.
CPU and RAM usage seem to be bellow 20%
I run on a gigabit fiber connection, and connected directly into a Archer C3200
In my tor logs I get:
Your Guard x is failing more circuits than usual. Most likely this means the Tor network is overloaded. Success counts are 102/157. Use counts are 79/79. 102 circuits completed, 0 were unusable, 0 collapsed, and 54 timed out. For reference, your timeout cutoff is 60 seconds.
If your guard node is failing, you could try using a different guard node if you really really want to:
How to change the entry node?
But according to this answer, you shouldn't have to:
Should I choose a new guard if the network is overloaded?
There are security implications to changing your guard node:
Why is a longer guard rotation period with fewer guards better than the other way around?
