Yandex.ru correctly shows the location of my provider ukrtelecom's pool - Kiev. I use Tor in high security mode.
Nothing helps - I tried Tor and VPNs.
Only yandex does this. There are no cookies inside Tor and Firefox.
How can I fix it?
dimitri
  • 31
  • Are you sure that you running Tor? Please visit check.torproject.org and check that you have configured it right. Translation to our Russian Tor user: Ты уверен что ты используешь Тор правильно? Посити check.torproject.org и проверь свои настройки. – NeverMine17 Jul 27 '17 at 15:50
  • I have checked: "Congratulations. This browser is configured to use Tor." – dimitri Jul 27 '17 at 16:02
  • Yandex determines my location also when I use Securitykiss VPN and ZenMate VPN. I have not found any way to hide from Yandex. – dimitri Jul 27 '17 at 16:04
  • There is a icon of a lock in top left corner. Press it and goto permissions. Block the "access your location" permission. – NeverMine17 Jul 27 '17 at 18:06
    You haven't logged in whilst using Tor, have you? – FMaz Jul 28 '17 at 06:08
  • @FynnMazurkiewicz have said the right thing. Please check if you logged in or not. – NeverMine17 Jul 28 '17 at 12:06
  • I am sorry to write here in Answer section. I registered incorrectly and stackexchange cut me off my question, so that I can not comment without 50 reputation. Comment to NeverMine: the lock icon shows "you have granted no special permissions to this site". I have checked about:config and see that geo.enabled is set to false – dimitri Jul 27 '17 at 19:20
