As title says, just wondering if anyone else is experiencing this issue. I have enabled NS and the whitelist is empty.
NS seems to be 'trusting' everything by default unless I mark each entry on a page specifically as Untrusted.
What happens on Google Maps after forbidding scripts globally: enter image description here
I have to manually mark every site as 'Untrusted' on this page, hit F5 and only then do I get the expected result:
I cannot figure out why NS is whitelisting everything by default unless I specify otherwise....
james-see
  • 344
Chris
Google Maps in the browser does not use Java but Javascript. No Script is great at blocking Javascript from loading and running at all.
You need to make sure No Script is set to block everything globally ("Forbid Scripts Globally").
Then whitelist specific sites and scripts as needed for the functionality you need per domain.
james-see
  • 344
