I'm writing a basic chat service, using php and javascript, and it works well on my localhost server(XAMPP), when I'm using Chrome. Once logged in, it takes you to a chatroom. The problem arises when I'm using the Tor Browser. It generates the *.onion hostname successfully, and I'm even able to login. I have to disable NoScript, else weird errors pop up. But once I disable it, the chat page refuses to send any data. I can send a message with another user on my local machine (on Chrome), and that message shows up in the Tor Browser, but I am unable to send anything from it. I have tried this on my mobile, to get the same result.
Below is the code for the chatroom-
<?php
    session_start();
    if(isset($_SESSION['user']))
        $usr= $_SESSION['user'];
    else if(isset($_SESSION['admin']))
        $usr = $_SESSION['admin'];
    else{
        echo "You haven't logged in. Go back, you sly fox/vixen.";
        echo "<br>"."Redirect in 5 seconds";
        header('Refresh: 5; URL= /');
        exit();
<html>
    <head>
        <title>chatbox</title>
        <script type="text/javascript" src = "../js/jquery-3.2.0.min.js"></script>
        <script>
            function submitChat() {
                if (form1.msg.value == ''){
                    alert('message, bruh?');
                    return;
                var msg = form1.msg.value;
                var xmlhttp = new XMLHttpRequest();
                xmlhttp.onreadystatechange = function() {
                    if (this.readyState == 4 && this.status == 200) {
                        var chatlogs = document.getElementById("chatlogs");
                        chatlogs.innerHTML = xmlhttp.responseText;
                xmlhttp.open('GET', 'insert.php?msg='+msg, true);
                xmlhttp.send();
            $(document).ready(function(e) {
                $.ajaxSetup({cache:false});
                setInterval(function(){$('#chatlogs').load('logs.php');}, 20);
        </script>
    </head>
<body>
    <form name="form1">
        Name: <?php echo "$usr";?><br />
        <div id="chatlogs" style="font-family: 'Courier New'; overflow-y: scroll; height : 400px;">
            If you're seeing this, disable NoScript.
        </div>
        Message: <br />
        <input type ='text' name="msg" style="font-family: 'Courier New';""><br />
        <input id="Send" type="submit" value="Send" onclick="submitChat();" /><br /><br />
    </form>
</body>
</html>
The function submitChat() passes data to insert.php-
<?php
    session_start();
    if (isset($_SESSION['user']))
        $uname = $_SESSION['user'];
    if (isset($_SESSION['admin']))
        $uname = $_SESSION['admin'];
    $msg = $_REQUEST['msg'];
    //header("Location: /dummy.php");
    $connect = new mysqli('localhost','root','pword','chatbox');
    mysqli_query($connect,"INSERT INTO logs (`uname`,`message`) VALUES ('$uname', '$msg')");
    $result = mysqli_query($connect,"SELECT * FROM logs ORDER BY id DESC");
    while($row=mysqli_fetch_array($result)){
            echo $row['uname'] . ": " . $row['message'] . "<br>";
All in all, nothing is inserted into the database. Any ideas?
Athena
  • 121
Alright. Got a solution. As @canonizingironize recommended, I looked at the Inspector window, the network pane. I had to modify my code slightly. Made the request interval to 1 second, so the server could cope, and added a check, to see if data is sent or not. If not, well, send again.
Resulting in -
                setInterval(function(){$('#chatlogs').load('logs.php');}, 1000);
and -
                while(xmlhttp.status != 200){
                    xmlhttp.send();
                    if (xmlhttp.status == 200)
                        break;
Thanks to @canonizingironize and @JanWytze for their inputs.
Athena
  • 121
