I am having a bit of trouble getting this to work. Can anyone help me resolve this problem?
3/17/2017 17:41:53 PM.400 [NOTICE] DisableNetwork is set. Tor will not make or accept non-control network connections. Shutting down all existing connections.
3/17/2017 17:41:53 PM.400 [NOTICE] Opening Socks listener on 127.0.0.1:9150
3/17/2017 17:41:53 PM.400 [NOTICE] Renaming old configuration file to "C:\Users\Owner\Desktop\Tor Browser\Browser\TorBrowser\Data\Tor\torrc.orig.1"
3/17/2017 17:41:54 PM.300 [NOTICE] Bootstrapped 5%: Connecting to directory server
3/17/2017 17:41:54 PM.300 [NOTICE] Bootstrapped 10%: Finishing handshake with directory server
3/17/2017 17:41:54 PM.500 [NOTICE] Bootstrapped 15%: Establishing an encrypted directory connection
3/17/2017 17:41:54 PM.500 [NOTICE] Bootstrapped 20%: Asking for networkstatus consensus
3/17/2017 17:41:54 PM.500 [NOTICE] Bootstrapped 25%: Loading networkstatus consensus
3/17/2017 17:41:55 PM.200 [NOTICE] I learned some more directory information, but not enough to build a circuit: We have no usable consensus.
3/17/2017 17:41:55 PM.500 [NOTICE] Bootstrapped 40%: Loading authority key certs
3/17/2017 17:41:55 PM.800 [NOTICE] Bootstrapped 45%: Asking for relay descriptors
3/17/2017 17:41:55 PM.800 [NOTICE] I learned some more directory information, but not enough to build a circuit: We need more microdescriptors: we have 0/7354, and can only build 0% of likely paths. (We have 0% of guards bw, 0% of midpoint bw, and 0% of exit bw = 0% of path bw.)
3/17/2017 17:41:56 PM.600 [NOTICE] Bootstrapped 50%: Loading relay descriptors
3/17/2017 17:41:58 PM.300 [NOTICE] Bootstrapped 56%: Loading relay descriptors
3/17/2017 17:41:58 PM.600 [NOTICE] Bootstrapped 64%: Loading relay descriptors
3/17/2017 17:41:58 PM.600 [NOTICE] Bootstrapped 73%: Loading relay descriptors
3/17/2017 17:41:58 PM.600 [NOTICE] Bootstrapped 80%: Connecting to the Tor network
3/17/2017 17:41:59 PM.300 [NOTICE] Bootstrapped 90%: Establishing a Tor circuit
3/17/2017 17:41:59 PM.700 [NOTICE] Tor has successfully opened a circuit. Looks like client functionality is working.
3/17/2017 17:41:59 PM.700 [NOTICE] Bootstrapped 100%: Done
3/17/2017 17:42:01 PM.000 [NOTICE] New control connection opened from 127.0.0.1.
3/17/2017 17:42:01 PM.100 [NOTICE] New control connection opened from 127.0.0.1.
3/17/2017 17:51:14 PM.300 [NOTICE] Tried for 120 seconds to get a connection to [scrubbed]:80. Giving up. (waiting for rendezvous desc)
Alexey Vesnin
  • 6,385
  • 15
  • 36
It's OK for a case when you have a ClientOnly mode, because it highly depends on your connection to get an actual HiddenService rendezvous points. If you have to use a client only mode - it's quite an often problem and you just have to wait, it will come up, but how quick - it's truly connection-dependent. If you have the chance - then make it a middle relay with reachable ORPort and DirPort - it will work fine after 2-3 minutes after bootup, timings verified even on 3G connection.
cacahuatl
  • 11,047
  • 17
  • 39
Alexey Vesnin
  • 6,385
  • 15
  • 36
