After wrestling with this myself, here's what worked for me on Trisquel 7.
Ingredients:-
Recipe:-
Add the following line to the torrc file (/etc/tor/torrc)
# For Freenode IRC
mapaddress 10.40.40.40 freenodeok2gncmy.onion
The address 10.40.40.40 is arbitrary, but it needs to be one that isn't going to be in use on your network.
Generate a client certificate and put it where irssi can find it
$ openssl req -x509 -sha256 -new -newkey rsa:4096 -days 1000 -nodes \
-out FreenodeTor.pem -keyout FreenodeTor.pem
Generating a 4096 bit RSA private key
Common Name (e.g. server FQDN or YOUR name) []: mary
$ mkdir -p ~/.irssi/certs
$ mv FreenodeTor.pem ~/.irssi/certs/
Set the "Common Name" to the registered nick (here, "mary"), the rest of the fields can be left blank (i.e. type .), but can probably be set to whatever you desire.
Also note the validity period should be whatever makes sense to you; here we have set it to 1000 days.
Print out the certificate's fingerprint; remember it
$ openssl x509 -in ~/.irssi/certs/FreenodeTor.pem -outform der \
| sha1sum -b | cut -d' ' -f1
Connect to freenode over the normal internet and associate the certificate with the nick
$ irssi
[(status)] /connect irc.freenode.net
[(status)] /msg NickServ identify <your password here>
[(status)] /msg NickServ CERT ADD <fingerprint from step 3.>
Add a new network and server to irssi
[(status)] /network add -sasl_username mary -sasl_password m1nt_54uc3 -sasl_mechanism EXTERNAL FreenodeTor
[(status)] /server add -ssl -ssl_cert ~/.irssi/certs/FreenodeTor.pem -net FreenodeTor 10.40.40.40 6697
This step didn't quite work correctly when I did it; I think because I left off -sasl_password. I had to go back and do a /network modify command to fix it. But don't worry, further below is what ~/.irssi/config should contain.
Add some info leakage prevention configuration
[(status)] /ignore * CTCPS
[(status)] /save
[(status)] /quit
The next step is to start irssi with torsocks, but first check that the irssi config contains something like the following:-
servers = (
address = "10.40.40.40";
chatnet = "FreenodeTor";
port = "6697";
use_tls = "yes";
tls_cert = "~/.irssi/certs/FreenodeTor.pem";
tls_verify = "no";
autoconnect = "no";
chatnets = {
FreenodeTor = {
type = "IRC";
max_kicks = "1";
max_msgs = "4";
max_whois = "1";
sasl_mechanism = "external";
sasl_username = "mary";
sasl_password = "m1nt_54uc3";
settings = {
core = { real_name = "mary"; user_name = "mary"; nick = "mary"; };
ignores = ( { level = "CTCPS"; } );
The final step:-
$ torsocks irssi
[(status)] /connect FreenodeTor
et voila! You should see something like:-
22:02 -!- Irssi: Connecting to 10.40.40.40 [10.40.40.40] port 6697
22:02 -!- Irssi: Certificate Chain:
22:02 -!- Irssi: Subject: CN: zettel.freenode.net
22:02 -!- Irssi: Issuer: C: US, O: Let's Encrypt, CN: Let's Encrypt Authority X3
22:02 -!- Irssi: Subject: C: US, O: Let's Encrypt, CN: Let's Encrypt Authority X3
22:02 -!- Irssi: Issuer: O: Digital Signature Trust Co., CN: DST Root CA X3
22:02 -!- Irssi: Protocol: TLSv1.2 (256 bit, DHE-RSA-AES256-GCM-SHA384)
22:02 -!- Irssi: EDH Key: 2048 bit DH
22:02 -!- Irssi: Public Key: 4096 bit RSA, valid from Mar 6 05:01:00 2017 GMT to Jun 4 05:01:00 2017 GMT
22:02 -!- Irssi: Public Key Fingerprint: E0:1B:31:80:56:D9:78:C4:2B:2D:3F:B2:DB:81:AB:03:15:59:BF:04:7E:31:E8:60:5F:98:07:A1:BB:8F:A3:0D (SHA256)
22:02 -!- Irssi: Certificate Fingerprint: B3:2B:29:0D:01:45:8F:3A:08:78:81:21:8B:72:CF:E4:9F:B1:53:D2:DB:AB:52:0B:38:2A:8F:94:ED:87:65:BA (SHA256)
22:02 -!- Irssi: Connection to 10.40.40.40 established
22:02 !zettel.freenode.net *** Looking up your hostname...
22:02 !zettel.freenode.net *** Couldn't look up your hostname
22:02 -!- mary!mary@127.0.0.1 mary You are now logged in as mary.
22:02 -!- SASL authentication succeeded
22:02 !zettel.freenode.net *** Spoofing your IP
22:02 -!- Welcome to the freenode Internet Relay Chat Network mary
22:02 -!- Your host is zettel.freenode.net[127.0.0.1/12345], running version ircd-seven-1.1.4
References:-
