I have updated to MAC OSX Sierra and now tor will open but just says: tor cannot connect to control port I have no firewall installed and no antivirus either. Can someone please advice what may be the issue or what a fix could be please? I have been using TOR for years and have never had an issue only now with Sierra there is an issue. Thanks
veedubz1
  • 31
  • This is not an answer. Forgive me as i do not know how to use this site yet. However i have encountered the same problem cannot connect to tor control port. i cannot open settings because of the same error and every time i re-download the same error occurs. i found this comment in another link but this doesn't help me as i cannot find this folder. perhaps this helps you: faced the same problem delete tor and from finder press - go - go to folder ~/Library/Application Support and delete the folder TorBrowser-Data then install 6.0.5. – Tor problem Sep 22 at 13:24 – Tommy Wong Nov 13 '16 at 12:01
I regret that I am slightly drunk plus doing this from memory, but I have suffered this exact same problem.
The issue is that a version of TorBrowser was released with a problem/feature that configuration files could not cope with space-characters in pathnames.
Unfortunately OSX likes to store configuration data in a folder called "$HOME/Library/Application[SPACE]Support" - and there are a lot of other directory names with spaces in them, in your OSX Library folder.
I can't recall precisely what I did to fix this, other than to manually check for anything Tor-related in my Library folder:
find ~/Library/ | egrep -i 'tor(project|browser)'
...and delete it; subsequent versions of the browser will stop picking up old, poisonous configuration files that way. DO NOT do this blindly because it will delete your bookmarks too. Copy those to a safe place, first.
Alec Muffett
  • 146
It appears if you execute the distributed Firefox using sudo it works.
So from the terminal try:
sudo /Applications/TorBrowser.app/Contents/MacOS/firefox
kenorb
  • 1,193
  • 13
  • 34
user15258
