I have torrc-default file and torrc custom file on mac at:
/Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor
folder (the package of the app).
In both files it is specified:
SocksPort 9150 IPv6Traffic PreferIPv6 KeepAliveIsolateSOCKSAuth
ControlPort 9151
But when I start tor from unix, it loads listening to 9050.
So I tried to look at configuration in [https://tor.stackexchange.com/a/11870]:
~/Library/Application Support/TorBrowser-Data/torrc
and here I find :
# This file was generated by Tor; if you edit it, comments will not be preserved
# The old torrc file was renamed to torrc.orig.1 or similar, and Tor will ignore it
DataDirectory /Applications/TorBrowser.app/TorBrowser/Data/Tor
So, where does the port 9050 come from?
EDITED after comment
I start the application from the folder where tor file is:
/Applications/TorBrowser.app/Contents/Resources/TorBrowser/Tor.
That folder also contains torrc and torrc-default files.
I tried:
./tor -f torrc
and:
Oct 28 20:16:17.741 [notice] Tor v0.2.8.7 (git-263088633a63982a) running on Darwin with Libevent 2.0.22-stable, OpenSSL 1.0.1t and Zlib 1.2.5.
Oct 28 20:16:17.742 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://www.torproject.org/download/download#warning
Oct 28 20:16:17.757 [warn] Unable to open configuration file "/Applications/TorBrowser.app/Contents/MacOS/Tor/torrc".
Oct 28 20:16:17.757 [err] Reading config failed--see warnings above.
