I am assuming you are building out a collector process that needs to get through Tor as fast as possible. Good luck to you!
There is a way:
Run your own relays and force by way of your torrc file to connect to your own relays. Set your relay bandwidth limits to be very high and set it to not publish that they exist to the larger Tor community.
This of course is not very secure at all and assumes that you even get accepted by Tor to receive the exit relay flag and the guard node flag.
This also kind of takes a crap on the Tor community by not letting anyone else use your fast relays.
But, to each their own! Do what thou wilt shall be the whole of the law. And also unfortunately, the wise one said "karma is a bitch."
