I tried different solution but it all failed,
First I tried to install Tails 2.4 to 8GB Kingston drive and it give error, 'insuficient free space', Drive is tested OK, no bad sectors, I then tried different usb slots - with same results. Then I tried to follow advice from forums to log in with password, I set password - tried to install - same result!
I used command line to install as SU, same error.
I then used 16GB kinston, exactly the same error. 32GB SD card - same result!
After that I setup VM and tried to install tails from VM, got this error:
Partitioning device /dev/sda
GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.UDisks2.Partition' on object at path /org/freedesktop/UDisks2/block_devices/sda1
Tails installation failed!
g-dbus-error-quark: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.UDisks2.Partition' on object at path /org/freedesktop/UDisks2/block_devices/sda1 (19)
So this is horrible, If anyone found the solution how to overcome this errors and install tails I would appreciate.
Jim8645
  • 61
Had the same problem today.
After (!) getting the error:
  • open "disks".
  • Select your sdcard (be sure to select the right one - in your case /dev/sda/)
  • Select the first partition.
  • Click on the gear symbol.
  • select "Format partition"
  • select type "FAT" (should be already selected)
  • click "Format"
  • restart installer
Then it worked for me.
fupduck
  • 111
