ExcludeSingleHopRelays 0
AllowSingleHopCircuits 1
AllowSingleHopExits 1
Does this configuration force Tor to behave just like common proxy without anonymity? How can I detect if Tor uses only one hop?
Tor configuration is set either by:
These options are set by the user - i.e. you - in the .torrc file. This is under your control. If you can't remember if you have set these options in the past, check your .torrc.
ExcludeSingleHopRelays is a configuration option for clients. By default this is set to 1 (i.e. True) to prevent single-hop circuits from being used.
AllowSingleHopCircuits is also a configuration option for clients. By default it's set to '0' to prevent single-hop circuits from being used.
These options are not set by you, but by the person running the Tor relay.
AllowSingleHopExits is a configuration option for servers. It allows the relay to be the sole relay in a single-hop circuit. By default it is 0 (i.e. False).
Is this config forces Tor to behave just like common proxy without anonymity? How can i detect, if tor uses only 1 hop?
These settings would allow you to use a single-hop circuit, but I don't believe they force a single-hop circuit. (I've checked by setting the client-side options in my config file, navigating to a page using the Tor Browser, and checking the drop-down Tor Circuit box. It has a normal 3-hop circuit.)
without anonymity?
Not necessarily. The destination site will still see the IP address of the exit node (i.e. the only node in your circuit). They won't see your original IP address. However, the single relay in your circuit can see your original IP address, so you are less anonymous to the that node than you would be if you used a normal 3-hop circuit.
You will know whether you have the client-side config options set in your .torrc, because you will have set them. At least with the Tor Browser you can check the hop count using the drop-down Tor Circuit box (by clicking on the onion icon).
