Route calculations are based around the available bandwidth of each of the candidate nodes for a given circuit. In the formulae in your question, W is the weight ascribed to a given node, with full decodes being shown below:
List of optional weights to apply to router bandwidths during path
selection. They are sorted in lexical order (as ASCII byte strings) and
values are divided by the consensus' "bwweightscale" param. Definition
of our known entries are...
Wgg - Weight for Guard-flagged nodes in the guard position
Wgm - Weight for non-flagged nodes in the guard Position
Wgd - Weight for Guard+Exit-flagged nodes in the guard Position
Wmg - Weight for Guard-flagged nodes in the middle Position
Wmm - Weight for non-flagged nodes in the middle Position
Wme - Weight for Exit-flagged nodes in the middle Position
Wmd - Weight for Guard+Exit flagged nodes in the middle Position
Weg - Weight for Guard flagged nodes in the exit Position
Wem - Weight for non-flagged nodes in the exit Position
Wee - Weight for Exit-flagged nodes in the exit Position
Wed - Weight for Guard+Exit-flagged nodes in the exit Position
Wgb - Weight for BEGIN_DIR-supporting Guard-flagged nodes
Wmb - Weight for BEGIN_DIR-supporting non-flagged nodes
Web - Weight for BEGIN_DIR-supporting Exit-flagged nodes
Wdb - Weight for BEGIN_DIR-supporting Guard+Exit-flagged nodes
Wbg - Weight for Guard flagged nodes for BEGIN_DIR requests
Wbm - Weight for non-flagged nodes for BEGIN_DIR requests
Wbe - Weight for Exit-flagged nodes for BEGIN_DIR requests
Wbd - Weight for Guard+Exit-flagged nodes for BEGIN_DIR requests
The algorithms used, together with the constraints placed on them, are explained in great detail in the Tor directory protocol document. I'd recommend taking a look at section "3.8.3. Computing Bandwidth Weights".
[The above list of decodes can be found in "3.4.1. Vote and consensus status document formats".]
The algorithms don't really lend themselves to concise explanations, so I won't go into further details here.
If you want to see the code, have a look at ./src/or/dirvote.c
