Recently, I started to study practical application of ZX calculus but I am confused by meaning of "diamond" and "loop".
Issue no. 1: There are these rules:
B-rule
and D-rule
But this example seems to use the rules wrongly:
In the middle of a digram, B-rule is used, however, I do not see any loop or diamonds justifying this step (i.e. a disconection of nodes).
Similar situation occurs in this example:
Why is it possible to ignore loop and diamonds?
Issue no. 2:
Interpreation of a diamond in Hilbert space is this:
Diamond = $\sqrt{2}$
What does mean that diamond is $\sqrt{2}$? Is it a normalization constant?
Interpreation of a loop in Hilbert space is this:
Loop represent the dimension of underlying Hilbert space
Assuming D-rule, loop should represent two diamonds hence $\sqrt{2}\sqrt{2} = 2$ which is dimension of Hilbert space for description of single qubit states. But ZX calculus can be used for any number of qubits. What does it mean that loop represent a dimension? How is a dimension of "multi-qubits" Hilbert space represented?
