Say I have a quantum circuit of $w+1$ qubits with a permutation gate (mapping computational basis states to computational basis states) that does the permutation $(i, i+1)(i+4, i+5)$ on $w+1$ qubits if $i$ is odd and the permutation $(i+1, i+2)(i+3, i+4)$ if $i$ is even, for some fixed $i$ in the range $1 \leq i \leq 2^W -2$. Is it possible to decompose the $(w+1)$-qubit permutation gate into some $w$-qubit permutation gates, $\mathrm{SWAP}$s and $\mathrm{NOT}$s? How? (Ideally, I'd like to avoid using $\mathrm{SWAP}$s and $\mathrm{NOT}$s due to certain implementation issues.)
I think it should be possible because of Lemma $2$ in the appendix of the paper Generating the group of reversible logic gates (Vos, Ra & Storme, 2002) (PDF):
The subgroup of exchangers $\mathbf{E}_w$, augmented with the $\text{NOT}$ gate and the $\text{CONTROLLED}^{w−2}$ $\text{NOT}$ gate, generates the group of even simple control gates.
but I'm not sure how to construct the circuit.
Sanchayan Dutta
  • 17,945
  • 50
  • 112
Consider some simpler cases, $(j,j+1)$ for general $j$. Then you can do you want with plugging in $j=i$, $j=i+1$, $j=i+3$ and $j=i+4$ and concatenating the circuits appropriately and then simplifying.
So how to do $(j,j+1)$? That is conjugate to $(0,1)$, so just consider that for now.
$(0,1)$ would be NOT but controlled on making sure all the higher places are $0$.
The conjugation that takes you between $(0,1)$ and $(j,j+1)$ is the circuit that does addition of $j$ modulo $2^{w+1}$. Reduce that to addition of $1$ modulo $2^{w+1}$ repeated.
So that decomposes your desired operation into a bunch of other computational basis to computational basis transformations. Construct the circuits for those, concatenate them all together in the specified order and then pass the resulting circuit through an optimizer.
Write down something that works even if it is inefficient first, then you can look for simplifications until you come up with something better. That might be more general advice as well.
AHusain
  • 3,723
  • 18
