I am introduced to ancilla qubits which are usually initialized to $\vert 0 \rangle$. It seems that an ancilla qubit is equivalent to the $0$ bit in classical computing as it will evaluate to $\vert 0 \rangle$ 100% of the time. My question is that can I conclude any qubit will always be in superposition regardless of the probabilities of $\alpha$ and $\beta$ since $\vert 0 \rangle + 0\vert 1 \rangle = \vert 0 \rangle$ and $0\vert 0 \rangle + \vert 1 \rangle = \vert 1 \rangle$? How about physically, are qubits prepared according to some procedure that differ if it will be initialized to $\vert 0 \rangle$ or $\vert 1 \rangle$ or in superposition?
Edit: this is a related comment but it doesn't answer my question regarding if the process of physically preparing qubits different from non-entangled qubits vs entangled ones.
M. Al Jumaily
  • 824
  • 19
Superposition is a basis dependent concept. Namely the $|0\rangle$ and $|1\rangle$ states are commonly said not to be superposition states exactly because one of the two coefficients in the $\{|0\rangle,|1\rangle\}$ basis expansion is zero. However, using the x-basis representation, $\{|+\rangle, |-\rangle\}$ one finds $|0\rangle = (|+\rangle + |-\rangle)/\sqrt{2}$ and $|1\rangle = (|+\rangle - |-\rangle)/\sqrt{2}$, which are superposition states with both coefficients non-zero.
Qubits naturally prepare themselves in the $|0\rangle$ state if one waits long enough (much longer than the T1 time) as it is the ground state of the system. To get any other state one must apply gates to the qubit that rotate the state to the desired position on the Bloch sphere.
epelaez
  • 2,985
  • 31
Paul Nation
  • 2,289
Yes, any state can always be described as a coherent superposition of some other set of states. "Being in a superposition" is not a property of just a quantum state, but rather a property of a quantum state relative to some basis. It doesn't make sense to talk of a superposition if not relative to a basis. We often don't explicitly specify this basis simply because it's usually obvious from the context which one is it.
glS
  • 27,510
  • 37
  • 125
