It is well known that a quantum computer is reversible. This means that it is possible to derive an input quantum state $|\psi_0\rangle$ from an output $|\psi_1\rangle$ of an algorithm described by a unitary matrix $U$ simply by applying transpose conjugate to $U$, i.e.
\begin{equation} |\psi_0\rangle = U^\dagger|\psi_1\rangle \end{equation}
In article Arrow of Time and its Reversal on IBM Quantum Computer an algorithm for a time reversal and going back to an input data $|\psi_0\rangle$ is proposed. Steps of the algorithm are following:
- Apply a forward time unitary evolution $U_\mathrm{nbit}|\psi_0\rangle = |\psi_1\rangle$
- Apply an operator $U_\psi$ to change $|\psi_1\rangle$ to $|\psi_1^*\rangle$, where the new state $|\psi_1^*\rangle$ is complex conjugate to $|\psi_1\rangle$
- Apply an operator $U_R$ to get "time-reversed" state $|R\psi_1\rangle$
- Finally, apply again $U_\mathrm{nbit}$ to obtain the input state $|\psi_0\rangle$
According to the paper, the algorithm described above simulates reversal of the time arrow. Or in other words, it simulates a random quantum fluctuation causing a time reversal.
Clearly, when the algorithm is run on a quantum computer, it returns back to initial state but without application of an inverse to each algorithm step. The algorithm simply goes forward.
My questions are these:
- Why it is not possible to say that an application of $U^\dagger$ on output of algorithm $U$ is reversal of time arrow in general case?
- It is true that above described algorithm returns a quantum computer to an initial state but it seems that the algorithm simply goes forward. So where I can see the a reversal of time arrow?
The authors of the articles have found out that when a number of qubit involved in the time reversal algorithm is increasing, the effect of time reversal diminishes:
How is it possible to reverse time for few qubits and concurently to preserve flowing of time in forward direction for another qubits?
Does this mean that time flows differently for different qubits?
When do the qubits return to commnon time frame to be possible to use them in another calculation?
