I'm trying to follow the instructions here https://qiskit.org/documentation/getting_started.html. It says
The default backend for qiskit.visualization.circuit_drawer() or QuantumCircuit.draw() is the text backend. However, depending on your local environment you may want to change these defaults to something better suited for your use case. This is done with the user config file. By default the user config file should be located in ~/.qiskit/settings.conf and is a .ini file.
I don't see this config file anywhere. Can anyone tell me how I can find the location of this file in order to make the change from the text based plotter to the nicer plotter?
