34
I have heard a few times that one way of describing quantum computers is that they essentially use the computing power of their counterparts in alternate realities that they access through superposition. My first question is, of course,
  1. is this actually an accurate description of how quantum computers work, or just a misrepresentation?
Also, if it were to be assumed true and taken literally, then presumably all the possible outcomes of any given computation done would be experienced by each of these alternate realities. I have a few questions regarding the implications of this:
  1. Would it be correct to say that our universe essentially "spawns" these alternate realities to use for each computation, or that they all exist simultaneously in a higher dimension and only come into contact via the initiation of superposition by each computer at the same time?
  2. Would it be possible to create contact between universes via this connection? I'd expect that, if it was, it would be entirely random, and so not only would not cause any information transfer, it also would be completely undetectable, because the deviations would be within the expected probabilities of error rates - but is there any way to circumvent this?
glS
  • 27,510
  • 37
  • 125
Snowshard
  • 477
Regarding your first question, you are essentially asking about the validity of a position taken by David Deutsch - a founder of quantum computing! For example, in his book 'The Fabric of Reality', Deutsch states:
When Shor’s algorithm has factorized a number, using $10^{500}$ or so times the computational resources that can be seen to be present, where was the number factorized? There are only about $10^{80}$ atoms in the entire visible universe, an utterly minuscule number compared with $10^{500}$. So if the visible universe were the extent of physical reality, physical reality would not even remotely contain the resources required to factorize such a large number. Who did factorize it, then? How, and where, was the computation performed?
The implication is that the number was factored in the multiverse.
However, there are some issues with Deutsch's position that others have pointed out.
For example, quantum computers can’t seem to access all of the multiverse to efficiently solve any problem - they still seem to have limitations! Aaronson, I believe in his book 'Quantum Computing Since Democritus', notes that Deutsch's arguments about multiple universes working together would apply equally well to problems in the so-called $\mathrm{NP\:Complete}$ complexity class. However, quantum computers likely cannot efficiently solve such problems.
So if we "use the computing power of their counterparts in alternate realities that they access through superposition," as espoused by Deutsch, then the computing power so-granted is still very limited - and then the question becomes why can the interacting universes within the multiverse allow us to factor large integers efficiently but not allow all other problems in $\mathrm{NP}$ to be solved efficiently?
Because the above question is not clearly answerable, the idea that the multiverse works together to factor a large number is maybe incomplete...
Mark Spinelli
  • 15,378
  • 26
  • 83
16
Question 1
This description lies somewhere between the two extremes of a theory and mysticism, depending on how amiable one is to the concept. David Deutsch is vocal proponent of the former, Lee Smolin of the latter (he categorizes it as "Mystical Realism").
The general idea was initiated by one of John Wheeler's PhD students, Hugh Everett III, in his 1957 doctoral thesis, which introduced relative state functions and provided the mathematical foundation for what is commonly known as the many-worlds interpretation (MWI).
In The Beginning of Infinity David Deutsch defines quantum computation as "Computation in which the flow of information is not confined to a single history." This definition is consistent with his expressed belief that MWI is a testable theory and the only theory with any power to explain the operation of quantum computers (here - note that Deutsch takes issue with the label MWI).
Deutsch is highly regarded and was the first to explicitly describe a universal quantum computer (ibid.). However, MWI is a minority view, and many other thought leaders disagree with his stance in this regard (see, e.g., Peter Shor's comment to Mark S's answer below). Another notable thinker, Richard Feynman, commented with regard to MWI, "It's possible, but I'm not very happy with it" (here).
To answer your question explicitly, it's not clear whether or not this is an accurate description.
Question 2
At a fundamental level, Everett describes the situation in his thesis:
...from the standpoint of our theory, it is not so much the system which is affected by an observation as the observer, who becomes correlated to the system.
Feynman expanded on this point of view (here),
...that many-world picture says that the wave function $\psi$ is what's real, and damn the torpedos if there are so many variables, $N^R$. All these different worlds and every arrangement of configurations are all there just like our arrangement of configurations, we just happen to be sitting in this one.
Deutsch has further refined the concept considerably over the years in both scientific papers (e.g., early: 1, 2; recent: 3) and popular science books (4, 5). He generally speaks of an infinite variety of universes within the multiverse, some proportion of which align with each other in particular instances.
In that sense, your second statement is closer to MWI. From what I understand, I think it would be more accurate to say the universes "doing the computation" were identical at the point of state preparation and branch on measurement.
Question 3
Contact in the form of "message sending" between universes is prohibited by special relativity. As stated by Everett (page 98-99 of his thesis)
Only the totality of these observer states, with their diverse knowledge, contains complete information about the original object-system state - but there is no possible communication between the observers described by these separate states.
If I understand Deutsch correctly, there is a possibility of some form of directed interference that would allow "an observer to 'feel' himself split into two branches" (experiment proposed here), but message sending between the two branches is still prohibited. Apparently, classification of MWI as interpretation or theory (under conventional scientific methodology) depends largely on the viability of this experiment, or one very similar.
Edit 1: Revised after reading Everett and Deutsch more carefully.
Edit 2: I recently learned that Sean Carroll (CalTech physicist and prolific writer) is also an advocate for the Everett formulation of quantum mechanics. He makes his case in Something Deeply Hidden.
Jonathan Trousdale
  • 3,452
  • 20
In the many worlds interpretation (MWI) reality consists of a structure called the multiverse that looks like a collection of slightly interacting parallel universes in some circumstances:
Deutsch, David. "The structure of the multiverse." Proceedings of the Royal Society of London. Series A: Mathematical, Physical and Engineering Sciences 458.2028 (2002): 2911-2923. [arXiv:quant-ph/0104033]
In the MWI each system exists in multiple instances. Some of those instances are identical to one another in the sense that any measurement you could perform on them can't tell them apart. These correspond to elements of a superposition that are in the same state $|\psi\rangle$. You can write this state as $1/2|\psi\rangle+1/2|\psi\rangle$, or $1/3|\psi\rangle+2/3|\psi\rangle$ or any other combination of numbers that add up to 1. A collection of instances in the same state can evolve to be in multiple different states, like so:
$$|\psi\rangle \to \tfrac{1}{\sqrt{2}}|\psi\rangle + \tfrac{1}{\sqrt{2}}|\alpha\rangle$$
There is no fact of the matter about which instances in the initial state $|\psi\rangle$ have ended up in the state $|\alpha\rangle$ because the instances in the same state can't be distinguished from one another by any measurement. So changing a superposition involves changing the state of some of the instances so that there are multiple different versions of the system. This process doesn't spawn the existence of new instances.
The interference that takes place in a quantum computation combines the information in the different instances to produce a single state with the correct outcome with some probability large enough to make the computation worth doing. Since the intermediate states are all combined to produce a single answer it's not the case that there is one version that receives messages from the other versions. Rather there is a process that uses all those versions to produce a correct answer. You can't copy information between different versions of a system because the process of copying information out of a system in a superposition produces decoherence that prevents interference:
Zurek, Wojciech H. "Wave-packet collapse and the core quantum postulates: Discreteness of quantum jumps from unitarity, repeatability, and actionable information." Physical Review A 87.5 (2013): 052111. [arXiv:1212.3245]
Interference is the process that puts information about all of the different versions into a single version so trying to copy information between different versions of the same system is forbidden by the laws of physics.
Sanchayan Dutta
  • 17,945
  • 50
  • 112
alanf
  • 191
The multiverse is not commonly accepted as the right description of reality and is just one of many interpretations of what exactly happens at the moment of the "wave function collapse". The multiverse is in its core just an idea to preserve determinism in nature by the argument: If you know in which exact universe you are, you can trace back every particle back to its original position at the big bang. This is not true in reality as quantum mechanics is inherently unpredictable (Copenhagen interpretation) or in the multiverse (we don't know in which universe we are).
So, if there are no multiverses then your entire question becomes pointless.
For the use in quantum mechanics (and therefore in quantum computers), it is probably more useful to understand how interference of wavefunctions works and interpret the computation in a quantum computer as constructive or destructive interference.
Sanchayan Dutta
  • 17,945
  • 50
  • 112
nerror
  • 17
