I am reading about the phase damping quantum operation on page 384 of Nielsen & Chuang's Quantum Computation and Quantum Information (10th Anniversary Edition).
Nielsen & Chuang derived the operation elements from an interaction model of two harmonic oscillators where only the first two levels $|0\rangle$ and $|1\rangle$ are considered. Here's a clipping of the corresponding contents in the book:
Another way to derive the phase damping operation is to consider an interaction between two harmonic oscillators, in a manner similar to how amplitude damping was derived in the last section, but this time with the interaction Hamiltonian \begin{equation} \tag{8.126} H = \chi a^\dagger a\left(b+b^\dagger\right), \end{equation} Letting $U = \exp\left(-iH\Delta t\right)$, considering only the $\left|0\right>$ and $\left|1\right>$ states of the $a$ oscillator as our system, and taking the environment oscillator to initially be $\left|0\right>$, we find that tracing over the environment gives the operation elements $E_k = \left<k_b|U|0_b\right>$, which are \begin{equation} \tag{8.127} E_0 = \begin{bmatrix}1 & 0 \\ 0 & \sqrt{1-\lambda}\end{bmatrix}\end{equation} \begin{equation} \tag{8.128} E_1 = \left[\begin{matrix} 0 & 0 \\ 0 & \sqrt{\lambda}\end{matrix}\right], \end{equation} where $\lambda = 1-\cos^2\left(\chi\Delta t\right)$
I just could not work out the calculations. Anybody can help me with the $\sqrt{1-\lambda}$ and $\sqrt{\lambda}$ terms?
Actually, when I attempted to derive the operation elements along this way, I got the very different answer:
Firstly, we know that if $[A,[A,B]]=[B,[A,B]]=0$ then $e^{A+B}=e^A e^B e^{-[A,B]/2}$. So we have $$E_0=\langle 0_b| e^{-i\chi\Delta t a^\dagger a(b+b^\dagger)} |0_b\rangle =\langle 0_b| e^{-i\chi\Delta t a^\dagger a b} e^{-i\chi\Delta t a^\dagger a b^\dagger} |0_b\rangle e^{(\chi\Delta t a^\dagger a)^2/2}$$Now using $$e^{-i\chi\Delta t a^\dagger a b^\dagger} |0_b\rangle = \sum_{n=0}^{\infty} \dfrac{(-i\chi\Delta t a^\dagger a)^n}{n!} (b^\dagger)^n |0_b\rangle = \sum_{n=0}^{\infty} \dfrac{(-i\chi\Delta t a^\dagger a)^n}{\sqrt{n!}} |n_b\rangle$$ and $$\langle 0_b| e^{-i\chi\Delta t a^\dagger a b} = \sum_{n=0}^{\infty} \langle 0_b| b^n \dfrac{(-i\chi\Delta t a^\dagger a)^n}{n!} = \sum_{n=0}^{\infty} \langle n_b| \dfrac{(-i\chi\Delta t a^\dagger a)^n}{\sqrt{n!}} $$ we are able to get $$E_0 = \sum_{n=0}^{\infty} \dfrac{(-i\chi\Delta t a^\dagger a)^{2n}}{n!} e^{(\chi\Delta t a^\dagger a)^2/2} = e^{-(\chi\Delta t a^\dagger a)^2/2}$$ Following the same line, using $$\langle 1_b| e^{-i\chi\Delta t a^\dagger a b} = \sum_{n=0}^{\infty} \langle 1_b| b^n \dfrac{(-i\chi\Delta t a^\dagger a)^n}{n!} = \sum_{n=1}^{\infty} \langle n_b| \dfrac{(-i\chi\Delta t a^\dagger a)^{n-1}}{\sqrt{n!}} n$$ we are to obtain $$E_1 = \sum_{n=0}^{\infty} \dfrac{(-i\chi\Delta t a^\dagger a)^{2n+1}}{n!} e^{(\chi\Delta t a^\dagger a)^2/2} = (-i\chi\Delta t a^\dagger a) e^{-(\chi\Delta t a^\dagger a)^2/2}$$
Therefore, my answer will be $E_{0}=\left[\begin{array}{cc}{1} & {0} \\ {0} & {e^{-(\chi\Delta t)^2/2}}\end{array}\right]$ and $E_{1}=\left[\begin{array}{cc}{0} & {0} \\ {0} & {-i\chi\Delta t e^{-(\chi\Delta t)^2/2}}\end{array}\right]$. What is the problem?
AYS
  • 23
Conn-CaoYK
  • 171
I am by no means an expert in this sort of calculation, but I think I (mostly) agree with you.
I divided the calculation up slightly differently, which simplified things notationally. Firstly, I considered the input $|0\rangle_A|0\rangle_B$. Clearly, $H$ acting on this is just 0, so this state doesn't evolve. So, the lop-left element of $E_0$ is 1, and that of $E_1$ is 0.
Then I considered the input $|1\rangle_A|0\rangle_B$. We know that $a^\dagger a$ will always just return $|1\rangle_A$, so we only need to consider the evolution of the second system, i.e. $$ e^{-i\chi\Delta t(b+b^\dagger)}|0\rangle_B. $$ We can then follow your strategy for the calculation (I've only gone through the $E_0$ case) to find the bottom-right element is $e^{-\Delta t^2\chi^2/2}$. (Digression: if I assume the b operators are fermionic, then $b+b^\dagger$ is basically just the Pauli $X$ matrix on a qubit. Then you recover the formula that's given.)
What at first glance seems confusing is why you should only consider $E_0$ and $E_1$. Surely, there are also $E_k$ for all natural numbers $k$? Of course, they will all be of the same form as $E_1$ up to some constant of proportionality. Let's assume $$ E_k=\alpha_k|1\rangle\langle 1| $$ for $k\geq 1$. Then the relevant terms of the Master equation look like $$ \sum_k\frac12 E_k^\dagger E_k\rho+\frac12\rho E_k^\dagger E_k-E_k\rho E_k^\dagger=\frac12 \beta|1\rangle\langle 1|\rho+\frac12 \beta\rho|1\rangle\langle 1|-\beta|1\rangle\langle 1|\rho|1\rangle\langle 1|. $$ This is entirely equivalent to the action of a single operator $E_1'=\sqrt{\beta}|1\rangle\langle 1|$ with $\beta=\sum_k\alpha_k^2$. Moreover, by the fact that the map will be trace preserving, I don't need to bother actually calculating $\beta$. I know that $$ \beta+\langle 1|E_0|1\rangle^2=1. $$ (At least this part is consistent with what N&C is telling us.)
DaftWullie
  • 62,671
  • 55
  • 140
Let us use a more explicit notation $H = \chi (a^\dagger \otimes a^\dagger a + a \otimes a^\dagger a)$, where $a$ is a generic annihilation operator. (Notice that N&C mean $b = a \otimes I$.) As you said, we use the formula $e^{A + B} = e^{-\frac{1}{2} [A, B]} e^A e^B$ for operators $A$ and $B$ which commute with their commutator. In this case, we get \begin{equation} U = e^{-\frac{1}{2} \chi^2 \Delta t^2 (I \otimes a^\dagger a)^2} e^{-i\chi \Delta t a^\dagger \otimes a^\dagger a} e^{-i\chi \Delta t a \otimes a^\dagger a}. \end{equation}
We want to compute the operation elements \begin{equation} E_k = (\langle k| \otimes I) U (| 0 \rangle \otimes I) = \sum_{l, m = 0}^\infty |l\rangle (\langle k| \otimes \langle l|) U (|0 \rangle \otimes |m \rangle) \langle m|. \end{equation}
Clearly $e^{-i\chi \Delta t a \otimes a^\dagger a} |0 \rangle \otimes |m \rangle = |0 \rangle \otimes |m \rangle$, and also \begin{align*} e^{-i\chi \Delta t a^\dagger \otimes a^\dagger a} |0 \rangle \otimes |m \rangle &= \sum_{n = 0}^\infty \frac{(-i\chi \Delta t)^n}{n!} (a^\dagger)^n |0 \rangle \otimes (a^\dagger a)^n |m \rangle \\ &= \sum_{n = 0}^\infty \frac{(-i\chi \Delta t m)^n}{\sqrt{n!}} |n \rangle \otimes |m \rangle. \end{align*}
Notice that in this expression we need to interpret $0^0 = 1$. Moreover, $|n \rangle \otimes |m \rangle$ is an eigenstate of $e^{-\frac{1}{2} \chi^2 \Delta t^2 (I \otimes a^\dagger a)^2}$ with eigenvalue $e^{-\frac{1}{2} \chi^2 \Delta t^2 m^2}$, so we obtain \begin{equation} (\langle k| \otimes \langle l|) U (|0 \rangle \otimes |m \rangle) = \delta_{lm} \frac{(-i\chi \Delta t m)^k}{\sqrt{k!}} e^{-\frac{1}{2} \chi^2 \Delta t^2 m^2}. \end{equation} Therefore \begin{equation} E_k = \sum_{m = 0}^\infty \frac{(-i\chi \Delta t m)^k}{\sqrt{k!}} e^{-\frac{1}{2} \chi^2 \Delta t^2 m^2} |m \rangle \langle m|, \end{equation} where again $0^0 = 1$.
Indeed, there is an operation element for each $k \in \mathbb{N}$, but now our assumption is that $\langle m| \rho |n \rangle$ is non-zero only for $m, n \in \{0, 1\}$. For such a state $\rho$ we get \begin{align*} \sum_{k = 0}^\infty E_k \rho E_k^\dagger &= \sum_{k, m, n = 0}^\infty \frac{(\chi^2 \Delta t^2)^k m^k n^k}{k!} e^{-\frac{1}{2} \chi^2 \Delta t^2 (m^2 + n^2)} |m \rangle \langle m| \rho |n \rangle \langle n| \\ &= \langle 0| \rho |0 \rangle |0 \rangle \langle 0| + \sum_{k = 0}^\infty \frac{(\chi^2 \Delta t^2)^k}{k!} e^{-\chi^2 \Delta t^2} \langle 1| \rho |1 \rangle |1 \rangle \langle 1| \\ &\quad+ e^{-\frac{1}{2} \chi^2 \Delta t^2} \langle 0| \rho |1 \rangle |0 \rangle \langle 1| + e^{-\frac{1}{2} \chi^2 \Delta t^2} \langle 1| \rho |0 \rangle |1 \rangle \langle 0| \\ &= \rho_{00} |0 \rangle \langle 0| + \rho_{11} |1 \rangle \langle 1| + e^{-\frac{1}{2} \chi^2 \Delta t^2} ( \rho_{01} |0 \rangle \langle 1| + \rho_{10} |1 \rangle \langle 0| ). \end{align*} This shows the exponential damping of the off-diagonal terms, just like one expects for decoherence. In matrix form this is indeed the same as $$ \left[ \begin{matrix} 1 & 0 \\ 0 & \sqrt{1 - \lambda} \end{matrix} \right] \left[ \begin{matrix} \rho_{00} & \rho_{01} \\ \rho_{10} & \rho_{11} \end{matrix} \right] \left[ \begin{matrix} 1 & 0 \\ 0 & \sqrt{1 - \lambda} \end{matrix} \right] + \left[ \begin{matrix} 0 & 0 \\ 0 & \sqrt{\lambda} \end{matrix} \right] \left[ \begin{matrix} \rho_{00} & \rho_{01} \\ \rho_{10} & \rho_{11} \end{matrix} \right] \left[ \begin{matrix} 0 & 0 \\ 0 & \sqrt{\lambda} \end{matrix} \right] $$ with $\sqrt{1 - \lambda} = e^{-\frac{1}{2} \chi^2 \Delta t^2}$. I think the cosine term is a mistake.
AYS
  • 23
