I am new to quantum computation and I recently came across the statement that super-dense coding can be called the inverse of quantum teleportation
In quantum teleportation, one starts with an entangled state shared between two parties, and (after some messing at the sender's side), two classical bits are transmitted from one party to the other so that the net effect is a quantum state is sent from the first party to the second without sending any quantum data.
In superdense coding, the parties start with an entangled state shared between two parties, and (after some messing at the sender's side), a quantum state is sent from one party to the other so that the net effect is two classical bits are sent from the first party to the second.
Hopefully I've written that in such a way that it conveys the symmetry between the two settings. Where I say "quantum state", I specifically mean a single qubit in an unknown state.
- 62,671
- 4
- 55
- 140
Basically quantum teleportation is in facto the determinate side of super-dense coding. In superdense coding we fit two classical bits of information using fairly a single qubit. On the other hand, quantum teleportation uses two classical bits of information to send a single qubit that is in an unknown quantum state. I suggest you to check IBM Q documentation for more details. Also, the “No Cloning Theorem” states that you cannot prevailingly clone a qubit in an unknown quantum state. Let’s delve a deeper into this to see why this is accurate.
Let's consider |⟩,|⟩, and |⟩ are vectors.
Given the sum |⟩ + |⟩ is a vector. The scalar product |⟩ is a vector and is a complex number ∈ ℂ.
- Commutativity: |⟩ + |⟩ = |⟩ + |⟩
- Associativity: (|⟩ + |⟩) + |⟩ = |⟩ + (|⟩ + |⟩)
- Distributive property for scalars and vectors:
- ( + )|⟩ = |⟩ + |⟩ where , ∈ ℂ
- (|⟩ + |⟩) = |⟩ + |⟩ where ∈ ℂ
- Associative property:
- (|⟩) = ()|⟩ where , ∈ ℂ
Then, consider that we could build a special unitary operator called U that could clone a qubit. This operator would take two qubits as input, one in an unknown state |⟩ and the other in a state such as |0⟩ that will undergo as our target for duplication. The cloning operator would then turn out with a copy of our qubit along with the original source qubit and both qubits will be in the same state |⟩.
For more detail, please check this paper: https://www.cs.mcgill.ca/~yli252/files/quantum.pdf
- 107
- 4
