The negativity of a density matrix is defined as $$ \mathcal{N}(\rho_{AB}) = \frac{1}{2} \bigl(\|\rho_{AB}^{T_A}\|_1 - 1\bigr), $$
where $\rho_{AB}$ is a density matrix on the bipartite system $A \otimes B$, $T_A$ denotes the partial transpose with respect to subsystem $A$, and $\|\cdot\|_1$ is the trace norm (sum of absolute values of the eigenvalues).
Question: What is known about the relationship between the entanglement negativity $\mathcal{N}(\rho_{AB})$ and the spectrum of the reduced density matrix $\rho_B = \mathrm{Tr}_A(\rho_{AB}^{T_A})$? Specifically, if the partial transpose $\rho_{AB}^{T_A}$ has negative eigenvalues, does that imply anything about the possibility of negative eigenvalues for $\rho_B$? (Note that $\rho_A$ remains positive semi-definite under transposition since the tranpose on subsytem $A$ is a positive map.)
