I am trying to get Quil-T working on rigetti.qpu.ankaa-3, using AzureQuantum.
I have the following which works perfectly:
import os
ID = "...."
os.environ["AZURE_QUANTUM_SUBSCRIPTION_ID"] = "ID" os.environ["AZURE_QUANTUM_WORKSPACE_RG"] = "AzureQuantum" os.environ["AZURE_QUANTUM_WORKSPACE_NAME"] = "Try100" os.environ["AZURE_QUANTUM_WORKSPACE_LOCATION"] = "UK South"
from azure.quantum import Workspace
workspace = Workspace( resource_id = "/subscriptions/ID/resourceGroups/AzureQuantum/providers/Microsoft.Quantum/Workspaces/Try100", location = "uksouth")
print("This workspace's targets:") for target in workspace.get_targets(): print("-", target.name)
from pyquil_for_azure_quantum import get_qpu, get_qvm from pyquil.gates import CNOT, MEASURE, H from pyquil.quil import Program from pyquil.quilbase import Declare
program = Program( Declare("ro", "BIT", 2), H(0), CNOT(0, 1), MEASURE(0, ("ro", 0)), MEASURE(1, ("ro", 1)), ).wrap_in_numshots_loop(10)
qpu = get_qpu("Ankaa-9Q-3") qvm = get_qvm()
exe = qpu.compile(program) # This does not run quilc yet. results = qpu.run(exe) # Quilc will run in the cloud before executing the program. qvm_results = qvm.run(exe) # This runs the program on QVM in the cloud, not locally.
However when i try the following:
qc = get_qpu("Ankaa-9Q-3")
qc.compiler.get_version_info()
I get the following error:
    "name": "GetISAError",
    "message": "Call failed during http request: error in refresh_qcs_token: Requested an access token for a configuration without credentials.",
    "stack": "---------------------------------------------------------------------------
GetISAError                               Traceback (most recent call last)
Cell In[28], line 8
      4 from pyquil_for_azure_quantum import get_qpu, get_qvm
      6 qc = get_qpu(\"Ankaa-9Q-3\")
----> 8 qc.compiler.get_version_info()
File /opt/anaconda3/envs/Quil/lib/python3.11/site-packages/pyquil_for_azure_quantum/init.py:78, in AzureQuantumComputer.init.<locals>.<lambda>() 75 def init(self, *, target: str, qpu_name: str): 76 # pylint: disable=abstract-class-instantiated 77 qam = AzureQuantumMachine(target=target) ---> 78 compiler = Proxy(lambda: get_qc(qpu_name).compiler) 79 super().init(name=qpu_name, qam=qam, compiler=compiler)
File /opt/anaconda3/envs/Quil/lib/python3.11/site-packages/pyquil/api/_quantum_computer.py:858, in get_qc(*failed resolving arguments*) 852 raise ValueError( 853 &quot;pyQuil currently does not support initializing a noisy QuantumComputer &quot; 854 &quot;based on a QCSQuantumProcessor. Change noisy to False or specify the name of a QVM.&quot; 855 ) 857 # 4. Not a special case, query the web for information about this quantum_processor. --> 858 quantum_processor = get_qcs_quantum_processor( 859 quantum_processor_id=prefix, client_configuration=client_configuration 860 ) 861 if qvm_type is not None: 862 # 4.1 QVM based on a real quantum_processor. 863 return _get_qvm_based_on_real_quantum_processor( 864 client_configuration=client_configuration, 865 name=name, (...) 872 qvm_client=qvm_client, 873 )
File /opt/anaconda3/envs/Quil/lib/python3.11/site-packages/pyquil/quantum_processor/qcs.py:76, in get_qcs_quantum_processor(quantum_processor_id, client_configuration, timeout) 62 def get_qcs_quantum_processor( 63 quantum_processor_id: str, 64 client_configuration: Optional[QCSClient] = None, 65 timeout: float = 10.0, 66 ) -> QCSQuantumProcessor: 67 &quot;&quot;&quot;Retrieve an instruction set architecture for the specified QPU ID and initialize a QCSQuantumProcessor with it. 68 69 :param quantum_processor_id: QCS ID for the quantum processor. (...) 74 :return: A QCSQuantumProcessor with the requested ISA. 75 &quot;&quot;&quot; ---> 76 isa = get_instruction_set_architecture(client=client_configuration, quantum_processor_id=quantum_processor_id) 78 return QCSQuantumProcessor(quantum_processor_id=quantum_processor_id, isa=isa)
GetISAError: Call failed during http request: error in refresh_qcs_token: Requested an access token for a configuration without credentials." }
Jack Jack
  • 51
