I am trying to compute some unitary matrix for some big circuit on GPU using qiskit-aer, specifically a 11 qubits circuit with the following error:
Simulation failed and returned the following error message:
ERROR: [Experiment 0] ChunkContainer::StoreUintParams size = 4107/266 iChunk = 0 : cudaErrorInvalidValue
I do not understand what the issue is or how to fix it, the same kind of circuit works with 10 qubits and I should not be short on memory as I am running the experiment on a 32gb V100
Here the code to reproduce the issue
import time
from qiskit import QuantumCircuit, transpile
from qiskit_aer import AerSimulator
from qiskit.quantum_info import random_unitary
seed = 42
def create_random_unitary(num_qubits, seed=None):
return random_unitary(2 ** num_qubits, seed=seed)
num_qubits = 11
circuit = QuantumCircuit(num_qubits)
gate1_qubits = list(range(0, num_qubits))
Gate 2 spans the second set of qubits
gate2_qubits = list(range(0, num_qubits))
left_unitary = create_random_unitary(len(gate1_qubits), seed)
right_unitary = create_random_unitary(len(gate2_qubits), seed)
circuit.unitary(left_unitary, gate1_qubits)
circuit.unitary(right_unitary, gate2_qubits)
save a fig of the circuit in pics folder
circuit.draw(output='mpl', filename=f'pics/{num_qubits}.png')
simulator = AerSimulator(method='unitary', device='GPU')
circuit.save_unitary()
transpiled_circuit = transpile(circuit, simulator) ## doesn't matter
start_time = time.time()
job = simulator.run(circuit)
result = job.result()
unitary_matrix = result.get_unitary(circuit)
end_time = time.time()
execution_time_ms = (end_time - start_time) * 1000
print(execution_time_ms)
