The GHZ game involves three non-communicating players, Alice, Bob, and Carol. They each receive a bit, $r,s,t$ with the guarantee that $r\oplus s\oplus t=0$ (i.e. with the guarantee that there are an even number of 1s). Their goal is to output $a,b,c$ respectively so $a\oplus b\oplus c=r\vee s\vee t$. The winning conditions are summarized in the table below:
| $rst$ | $a\oplus b\oplus c$ |
| 000 | 0 |
| 011 | 1 |
| 101 | 1 |
| 110 | 1 |
A strategy which works is for them to share the entangled state $$\frac{1}{\sqrt{2}}\left(|000\rangle+|111\rangle\right).$$ If they see a $0$, they apply the $X$-gate. If they see a $1$, they apply a $Y$-gate. It can be shown that this is a winning strategy since after applying the respective gates, we end up with a superposition of states with the required parities.
However, they could have also done this with the state $$\frac{1}{2}\left(|000\rangle-|011\rangle-|101\rangle-|110\rangle\right),$$ and applying a Hadamard on $r,s,t=1$ and doing nothing otherwise.
I am aware that in order to determine when a three qubit state $|\psi\rangle$ can yield a winning strategy has something to do with correlations they satisfy, but I have no idea what this means really. What I know is that the gate Alice applies to the state $|\psi\rangle$ is a function of the bit $r$ she receives. Call it $M_r$. Similarly, the gates Bob, Carol apply can be called $M_s,M_t$. Thus the net effect on the state is $M_{rst}=M_r\otimes M_s\otimes M_t$. The goal is that this gate should be such that $$M_{rst}|\psi\rangle$$ should result in a superposition state where the parity of each state is even in the event $r=s=t=0$ and in a superposition state where the parity of each state should be odd in the other events. But how can I use this to impose restrictions on the allowed "GHZ states" $|\psi\rangle$ if $M_r,M_s,M_t$ are just arbitrary gates?
