There is a simple circuit with one CNOT like the following:
  • Topology 0 → 1 (directed connection)
  • CNOT 1 → 0
Note that CNOT is placed opposite to the connection.
If this is transpiled correctly, it should look like the following circuit.
  1. HH
  2. CNOT 0 → 1
  3. HH
What is the proper Tket transpilation pass(es) required to perform this transpilation?
I wrote the following code but did not get the desired result.
from pytket import Circuit
from pytket.circuit import Node
from pytket.architecture import Architecture
from pytket.placement import place_with_map
from pytket.passes import RoutingPass
nodes = [Node("node" + str(i), i) for i in range(2)] arch = Architecture([(nodes[1], nodes[0])])
circuit = Circuit(2) circuit.CX(0, 1) # needs transpilation here
initial_mapping = {circuit.qubits[i]: nodes[i] for i in range(len(nodes))} place_with_map(circuit, initial_mapping)
transpile
RoutingPass(arch).apply(circuit)
FDGod
  • 2,901
  • 31
yasuhito
  • 91
DecomposeSwapsToCXs looks like it does the trick.
from pytket.passes import DecomposeSwapsToCXs
from pytket.circuit.display import render_circuit_jupyter
circuit = Circuit(2) circuit.CX(0, 1) # needs transpilation here print("Original circuit:") render_circuit_jupyter(circuit)
nodes = [Node("node" + str(i), i) for i in range(circuit.n_qubits)] arch = Architecture([(nodes[1], nodes[0])])
initial_mapping = {circuit.qubits[i]: nodes[i] for i in range(circuit.n_qubits)} place_with_map(circuit, initial_mapping)
DecomposeSwapsToCXs(arch, True).apply(circuit) print("\nTranspiled circuit after applying DecomposeSwapsToCXs:") render_circuit_jupyter(circuit)
FDGod
  • 2,901
  • 31
yasuhito
  • 91
