I'm working on a project involving quantum support vector machines using the method from the Quantum Kernel Machine Learning Tutorial by the Qiskit community. While implementing the code on a real IBM quantum machine, I encountered CircuitError: "name conflict adding parameter 'x[1]'" error.
Has anyone faced this issue, or does anyone know how to resolve it? Any insights would be appreciated!
Code:
    from qiskit_ibm_runtime import QiskitRuntimeService, Sampler, Session
    from qiskit_machine_learning.datasets import ad_hoc_data
    from qiskit import transpile
    from qiskit.circuit.library import ZZFeatureMap
    from qiskit_algorithms.state_fidelities import ComputeUncompute
    from qiskit_machine_learning.kernels import FidelityQuantumKernel
    from qiskit.transpiler.preset_passmanagers import generate_preset_pass_manager
# Load Dataset
adhoc_dimension = 2
train_features, train_labels, test_features, test_labels, adhoc_total = ad_hoc_data(
    training_size=20,
    test_size=5,
    n=adhoc_dimension,
    gap=0.3,
    plot_data=False,
    one_hot=False,
    include_sample_total=True,
# initialize backend service
service = QiskitRuntimeService()
n_qubits=2
backend = service.least_busy(operational=True, simulator=False, min_num_qubits=n_qubits)
adhoc_feature_map = ZZFeatureMap(feature_dimension=adhoc_dimension, reps=2, entanglement="linear")
#transpile circuit
pass_manager = generate_preset_pass_manager(optimization_level=1, backend=backend)
isa_circuit = pass_manager.run(adhoc_feature_map)
# calculate kernel matrices
with Session(service= service, backend=backend) as session:
    sampler = Sampler(backend)
    fidelity = ComputeUncompute(sampler=sampler)
    adhoc_kernel = FidelityQuantumKernel(fidelity=fidelity, feature_map=isa_circuit)
    adhoc_matrix_train = adhoc_kernel.evaluate(x_vec=train_features,y_vec=train_features)
    adhoc_matrix_test = adhoc_kernel.evaluate(x_vec=test_features, y_vec=train_features)
Got following error:
CircuitError                              Traceback (most recent call last)
Cell In[51], line 7
      4 fidelity = ComputeUncompute(sampler=sampler)
      6 adhoc_kernel = FidelityQuantumKernel(fidelity=fidelity, feature_map=isa_circuit)
----> 7 adhoc_matrix_train = adhoc_kernel.evaluate(x_vec=train_features,y_vec=train_features)
      8 adhoc_matrix_test = adhoc_kernel.evaluate(x_vec=test_features, y_vec=train_features)
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit_machine_learning/kernels/fidelity_quantum_kernel.py:114, in FidelityQuantumKernel.evaluate(self, x_vec, y_vec) 112 if is_symmetric: 113 left_parameters, right_parameters, indices = self._get_symmetric_parameterization(x_vec) --> 114 kernel_matrix = self._get_symmetric_kernel_matrix( 115 kernel_shape, left_parameters, right_parameters, indices 116 ) 117 else: 118 left_parameters, right_parameters, indices = self._get_parameterization(x_vec, y_vec)
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit_machine_learning/kernels/fidelity_quantum_kernel.py:202, in FidelityQuantumKernel._get_symmetric_kernel_matrix(self, kernel_shape, left_parameters, right_parameters, indices) 192 def _get_symmetric_kernel_matrix( 193 self, 194 kernel_shape: tuple[int, int], (...) 197 indices: KernelIndices, 198 ) -> np.ndarray: 199 """ 200 Given a set of parameterization, this computes the kernel matrix. 201 """ --> 202 kernel_entries = self._get_kernel_entries(left_parameters, right_parameters) 203 kernel_matrix = np.ones(kernel_shape) 205 for i, (col, row) in enumerate(indices):
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit_machine_learning/kernels/fidelity_quantum_kernel.py:223, in FidelityQuantumKernel._get_kernel_entries(self, left_parameters, right_parameters) 221 if num_circuits != 0: 222 if self.max_circuits_per_job is None: --> 223 job = self._fidelity.run( 224 [self._feature_map] * num_circuits, 225 [self._feature_map] * num_circuits, 226 left_parameters, 227 right_parameters, 228 ) 229 kernel_entries = job.result().fidelities 230 else: 231 # Determine the number of chunks needed
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit_algorithms/state_fidelities/base_state_fidelity.py:298, in BaseStateFidelity.run(self, circuits_1, circuits_2, values_1, values_2, options) 270 def run( 271 self, 272 circuits_1: QuantumCircuit | Sequence[QuantumCircuit], (...) 276 options, 277 ) -> AlgorithmJob: 278 r""" 279 Runs asynchronously the state overlap (fidelity) calculation between two 280 (parametrized) circuits (first and second) for a specific set of parameter (...) 296 The job's result is an instance of :class:.StateFidelityResult. 297 """ --> 298 job = self._run(circuits_1, circuits_2, values_1, values_2, **options) 300 job.submit() 301 return job
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit_algorithms/state_fidelities/compute_uncompute.py:147, in ComputeUncompute._run(self, circuits_1, circuits_2, values_1, values_2, options) 116 def _run( 117 self, 118 circuits_1: QuantumCircuit | Sequence[QuantumCircuit], (...) 122 options, 123 ) -> AlgorithmJob: 124 r""" 125 Computes the state overlap (fidelity) calculation between two 126 (parametrized) circuits (first and second) for a specific set of parameter (...) 144 AlgorithmError: If the sampler job is not completed successfully. 145 """ --> 147 circuits = self._construct_circuits(circuits_1, circuits_2) 148 if len(circuits) == 0: 149 raise ValueError( 150 "At least one pair of circuits must be defined to calculate the state overlap." 151 )
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit_algorithms/state_fidelities/base_state_fidelity.py:187, in BaseStateFidelity._construct_circuits(self, circuits_1, circuits_2) 184 # re-parametrize input circuits 185 # TODO: make smarter checks to avoid unnecessary re-parametrizations 186 parameters_1 = ParameterVector("x", circuit_1.num_parameters) --> 187 parametrized_circuit_1 = circuit_1.assign_parameters(parameters_1) 188 parameters_2 = ParameterVector("y", circuit_2.num_parameters) 189 parametrized_circuit_2 = circuit_2.assign_parameters(parameters_2)
File ~/Desktop/IMB/machine/lib/python3.11/site-packages/qiskit/circuit/quantumcircuit.py:4345, in QuantumCircuit.assign_parameters(self, parameters, inplace, flat_input, strict) 4343 else: 4344 parameter_binds = _ParameterBindsSequence(target._data.parameters, parameters) -> 4345 target._data.assign_parameters_iterable(parameters) 4347 # Finally, assign the parameters inside any of the calibrations. We don't track these in 4348 # the ParameterTable, so we manually reconstruct things. 4349 def map_calibration(qubits, parameters, schedule):
CircuitError: "name conflict adding parameter 'x[1]'" ```
