Indeed bipartite pure quantum states can be certified using self-testing, but this may not be the most practical nor efficient way to gain information about an unknown quantum state in many settings. In particular, you must remember that the context for self-testing is the device-independent paradigm, where the quantum devices are untrusted. This is distinguished from quantum tomography where we are provided with a quantum state (or many copies) and want to learn something about it. Here are some more distinctions:
- The self-testing protocol in [2]
requires two non-communicating quantum devices that share the target
quantum state. This is already much more complicated than the setting
of [1] where just a single quantum device is required. Not to
mention, the issues with the non-communicating assumption itself.
- To inspect the correlation from the self-testing scenario
in [2] one needs to perform multiple rounds to get an accurate
description of the correlation. So there isn't an advantage to
self-testing over the need for multiple copies of the state in [1].
- The protocol in [2] works only for bipartite pure
states, while the protocol in [1] does not have this caveat.
- Unlike in [1] the complexity of the measurements required in [2] is not clear. Although general self-testing typically allows one to effectively certify the measurements in addition to the state, I believe the protocol in [2] lacks this property.
- Although the procedure in [1] is superior in most contexts, the advantage of the procedure in [2] is the device-independent nature of the certification protocol.
- Lastly, a self-test only certifies a state up to local isometries it does not exactly imply that the target state and the employed state are close in norm (or fidelity).
[1] Certifying almost all quantum states with
few single-qubit measurements, https://arxiv.org/pdf/2404.07281
[2] All Pure Bipartite Entangled States can be Self-Tested, https://arxiv.org/pdf/1611.08062
