I'm currently trying to implement the depolarizing channel on qiskit. But, as I see in my calculation it doesn't match with the qiskit aer_noise.
So, for the Depolarizing Channel we got : $$ \mathcal{E}(\rho) = (1 - p) \rho + p \frac{I}{2} $$
Ant the choi matrix equation is: $$ \Lambda_\mathcal{E} = (\mathcal{I} \otimes \mathcal{E})(|\Phi\rangle \langle \Phi|) $$ So, this is the tricky part where i get lost, I know that the Choi matrix got the Channel acting in every ketbra on the base, so in this case, for a one qubit i got: $$ \mathcal{E}(|0\rangle \langle 1|) = (1-p) |0\rangle \langle 1| + p/2 (|0\rangle \langle 0| + |1\rangle \langle 1|) $$ $$ \mathcal{E}(|1\rangle \langle 0|) = (1-p) |1\rangle \langle 0| + p/2 (|0\rangle \langle 0| + |1\rangle \langle 1|) $$ $$ \mathcal{E}(|0\rangle \langle 0|) = (1-p/2) (|0\rangle \langle 0|) + p/2 (|1\rangle \langle 1|) $$ $$ \mathcal{E}(|1\rangle \langle 1|) = (1-p/2) (|1\rangle \langle 1|) + p/2 (|0\rangle \langle 0|) $$
Sho, the Choi matrix for this channel would be $$ \Lambda_\mathcal{E}= \begin{pmatrix} 1 - \frac{p}{2} & 0 & \frac{p}{2} & 1 - p \\ 0 & \frac{p}{2} & 0 & \frac{p}{2} \\ \frac{p}{2} & 0 & \frac{p}{2} & 0 \\ 1 - p & \frac{p}{2} & 0 & 1 - \frac{p}{2} \end{pmatrix} $$. However, if I use the qiskit funciton aer.get_noise and later use the Choi(noise) i get the form : $$ \Lambda_\mathcal{E}= \begin{pmatrix} 1 - \frac{p}{2} & 0 & 0 & 1 - p \\ 0 & \frac{p}{2} & 0 & 0\\ 0 & 0 & \frac{p}{2} & 0 \\ 1 - p & 0 & 0 & 1 - \frac{p}{2} \end{pmatrix} $$.
Can someone help me to understand why is the second form? Thanks.
