There is a machine called oracle which appears in a lot of algorithm of quantum computing, such as Deutsch's algorithm, QFT period-finding. This oracle machine really makes me confused. I've read something about computing theory, and in that, it mentions the oracle as a machine which have a super magic power that can solve a specific question.
If I am not not wrong, I remember the oracle machine firstly appears in Turing's paper, it is a black box which can solve a specific hard question. But Turing just use it to do some mathematical deduction and develop a mathematical theory, that's fine.
But here comes the triky part, if these quantum algorithms depends on such a super magic power machine, doesn't that mean that all these algorithms are no use in real life? Since we don't have the magic to make that oracle.
How can we implement that oracale machine in the real world? You can use Deutsch's algorithm as an example to illustrate this idea.
Cross-posted on physics.stackexchange
Martin Vesely
  • 15,244
  • 32
  • 75
tangyao
  • 191
There are a couple of different bits of the philosophy of how we use oracles that we need to touch on here:
  • when we use an oracle, it's often trying to make some claims about how fast the algorithm would run if we had such an oracle. In a sense, it doesn't really matter if you can build such a device or not. Is it unfair to give a quantum computer access to a magical device? What we're comparing it to is a classical computer with access to (more or less*) the same magical device. So long as the two are compared on as equal a footing as possible, that's all that matters.
  • the value of an oracle is not usually about how magical it is or not. All the standard ones in quantum computing are very non-magical: they're just classical function evaluations which are easily constructed. Instead, the value of the oracle is to put you in a straight jacket and say "you must solve the problem like this..", so that you can make conclusions "when I solve the problem like this, quantum is faster than classical by some factor ...". Of course, in the real world, you can solve the problem in whatever way you want. Generally, the oracles are designed to replicate they way we would expect to do the computation in reality, but we cannot generally prove there isn't a better way.
As for the example of Deutsch's algorithm, your oracle has to have two bits of input ($x,y$) and two bits of output ($x,y\oplus f(x)$) for some function $f(x)$. We need to examples, a constant function and a balanced function. For the constant function, let's assume that $f(0)=f(1)=0$. Then the output is $x,y$. In other words, exactly the same as the input. This "magic" is just two quantum wires.
For the balanced function, let's take $f(x)=x$. Then all we have to do is apply a controlled-not, controlled off the $x$ qubit and targeting the $y$ qubit.
*The quantum and classical oracles can be defined to behave in exactly the same way on classical inputs, i.e. $(x,y)\rightarrow (x,y\oplus f(x))$. Of course, the quantum oracle is a little different as it has to also act on superpositions of inputs. Not everyone feels like this makes a fair comparison.
DaftWullie
  • 62,671
  • 55
  • 140
