I try to simulate two-qubit erasure error by using CORRELATED_ERROR, ELSE_CORRELATED_ERROR, and an ancilla which is mentioned in How do I perform an erasure error in stim?. Then I simulate two-qubit erasure error in surface code by following codes.
pro = [0.00625, 0.006289308176100629, 0.006329113924050633, 0.006369426751592357, 0.006410256410256411, 0.006451612903225807, 0.006493506493506495, 0.006535947712418302, 0.006578947368421053, 0.006622516556291391, 0.006666666666666667, 0.006711409395973155, 0.006756756756756757, 0.006802721088435375, 0.006849315068493151, 0.006896551724137932]
circuit = stim.Circuit(f""" R 1 2 999 E({pro[0]}) X999 ELSE_CORRELATED_ERROR({pro[1]}) X2 X999 ELSE_CORRELATED_ERROR({pro[2]}) Y2 X999 ELSE_CORRELATED_ERROR({pro[3]}) Z2 X999 ELSE_CORRELATED_ERROR({pro[4]}) X1 X999 ELSE_CORRELATED_ERROR({pro[5]}) X1 X2 X999 ELSE_CORRELATED_ERROR({pro[6]}) X1 Y2 X999 ELSE_CORRELATED_ERROR({pro[7]}) X1 Z2 X999 ELSE_CORRELATED_ERROR({pro[8]}) Y1 X999 ELSE_CORRELATED_ERROR({pro[9]}) Y1 X2 X999 ELSE_CORRELATED_ERROR({pro[10]}) Y1 Y2 X999 ELSE_CORRELATED_ERROR({pro[11]}) Y1 Z2 X999 ELSE_CORRELATED_ERROR({pro[12]}) Z1 X999 ELSE_CORRELATED_ERROR({pro[13]}) Z1 X2 X999 ELSE_CORRELATED_ERROR({pro[14]}) Z1 Y2 X999 ELSE_CORRELATED_ERROR({pro[15]}) Z1 Z2 X999 M 999 DETECTOR rec[-1] """)
The pro array is chosen to ensure that the probability of each error mode is 0.00625. And I replace DEPOLARIZE2 error with the noise described in code and expect I will get a higher threshold because it gives information on the specific gate where the loss occurred. However, the result is that I get a lower threshold.
Is there a feasible way to simulate a two-qubit erasure error?
You Chang
