I am using the code for generating the gates for qu8it
The resultant gate is not unitary (and so not hermitian too). I am a bit confused with the result. Is it possible for a quantum gate to be non-unitary? When I take the just real or just imaginary part of the matrix, then it is unitary. Is the code have some missing part or am I missing some fact about qudits?
This is the code thanks to @unknown :
 TestA:=function(p)local Ig,Zg,Xg,Hg,Pg,grp,cen,sgrp,scen,C;
 Ig:=IdentityMat(p);
 Zg:=DiagonalMat(List([0..p-1],x->E(p)^x));
 Xg:=IdentityMat(p){\mod([0..p-1]+1,p)+1};
 Hg:=List([0..p-1],x->List([0..p-1],y->E(p)^(x*y)))/ER(p);
 Pg:=DiagonalMat(List([0..p-1],x->E(2*p)^(x*(x-\mod(p,2)))));
 grp:=Group([Hg,Pg,Zg]);cen:=Center(grp);sgrp:=Size(grp);scen:=Size(cen);
 Print(" |G| = ",String(sgrp,-5));Print(" |Cen(G)| = ",String(scen,-5));Print(" |G/Cen(G)| = ",String(sgrp/scen,-5));Print("\n");
 if(p=8)then
 Print("Z=\n");PrintArray(Zg);
 Print("X=\n");PrintArray(Xg);
 Print("H=\n");PrintArray(Hg);
 Print("P=\n");PrintArray(Pg);
 C:=KroneckerProduct([[1,0],[0,1]],[[1,1],[1,-1]]/ER(2));C:=C{[1,3,2,4]}{[1,3,2,4]};
 Zg:=C^-1*Zg*C;
 Xg:=C^-1*Xg*C;
 Hg:=C^-1*Hg*C;
 Pg:=C^-1*Pg*C;
 Print(" all elements are monomial? ",ForAll(Elements(grp),IsMonomialMatrix),"\n");
 fi;
return grp;end;
g2:=TestA(2);; g4:=TestA(4);; g8:=TestA(8);;
This is the qu8it Hadamard:
    a=1j
b=0.707+0.707j
qudit_8_H = Qobj([ [   1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b-1/4*b**3 ],
  [   1/4*b-1/4*b**3,          1/4+1/4*a,   1/4*b+1/4*b**3,         -1/4+1/4*a,  -1/4*b+1/4*b**3,         -1/4-1/4*a,  -1/4*b-1/4*b**3,          1/4-1/4*a ],
  [   1/4*b-1/4*b**3,   1/4*b+1/4*b**3,  -1/4*b+1/4*b**3,  -1/4*b-1/4*b**3,   1/4*b-1/4*b**3,   1/4*b+1/4*b**3,  -1/4*b+1/4*b**3,  -1/4*b-1/4*b**3 ],
  [   1/4*b-1/4*b**3,         -1/4+1/4*a,  -1/4*b-1/4*b**3,          1/4+1/4*a,  -1/4*b+1/4*b**3,          1/4-1/4*a,   1/4*b+1/4*b**3,         -1/4-1/4*a ],
  [   1/4*b-1/4*b**3,  -1/4*b+1/4*b**3,   1/4*b-1/4*b**3,  -1/4*b+1/4*b**3,   1/4*b-1/4*b**3,  -1/4*b+1/4*b**3,   1/4*b-1/4*b**3,  -1/4*b+1/4*b**3 ],
  [   1/4*b-1/4*b**3,         -1/4-1/4*a,   1/4*b+1/4*b**3,          1/4-1/4*a,  -1/4*b+1/4*b**3,          1/4+1/4*a,  -1/4*b-1/4*b**3,         -1/4+1/4*a ],
  [   1/4*b-1/4*b**3,  -1/4*b-1/4*b**3,  -1/4*b+1/4*b**3,   1/4*b+1/4*b**3,   1/4*b-1/4*b**3,  -1/4*b-1/4*b**3,  -1/4*b+1/4*b**3,   1/4*b+1/4*b**3 ],
  [   1/4*b-1/4*b**3,          1/4-1/4*a,  -1/4*b-1/4*b**3,         -1/4-1/4*a,  -1/4*b+1/4*b**3,         -1/4+1/4*a,   1/4*b+1/4*b**3,          1/4+1/4*a ] ]
quest
  • 704
All these gates are in fact unitary. Since you're not using GAP and working with floating point, it's possible there are numerical precision issues that are affecting your tests. Here's a test that shows the check for unitarity in GAP :
TestB:=function(p)local Ig,Zg,Xg,Hg,Pg,gates;
 Ig:=IdentityMat(p);
 Print("check Z unitary : ",Zg*TransposedMat(GaloisCyc(Zg,-1))=Ig,"\n");
 Print("check X unitary : ",Xg*TransposedMat(GaloisCyc(Xg,-1))=Ig,"\n");
 Print("check H unitary : ",Hg*TransposedMat(GaloisCyc(Hg,-1))=Ig,"\n");
 Print("check P unitary : ",Pg*TransposedMat(GaloisCyc(Pg,-1))=Ig,"\n");
 Print("sqrt(p)*H=\n");PrintArray(ER(p)*Hg);
 return Hg;
end;
The results (takes much less time than TestA because the group is not being calculated) :
H8:=TestB(8);;
check Z unitary : true
check X unitary : true
check H unitary : true
check P unitary : true
Z=
[ [        1,        0,        0,        0,        0,        0,        0,        0 ],
  [        0,     E(8),        0,        0,        0,        0,        0,        0 ],
  [        0,        0,     E(4),        0,        0,        0,        0,        0 ],
  [        0,        0,        0,   E(8)^3,        0,        0,        0,        0 ],
  [        0,        0,        0,        0,       -1,        0,        0,        0 ],
  [        0,        0,        0,        0,        0,    -E(8),        0,        0 ],
  [        0,        0,        0,        0,        0,        0,    -E(4),        0 ],
  [        0,        0,        0,        0,        0,        0,        0,  -E(8)^3 ] ]
X=
[ [  0,  1,  0,  0,  0,  0,  0,  0 ],
  [  0,  0,  1,  0,  0,  0,  0,  0 ],
  [  0,  0,  0,  1,  0,  0,  0,  0 ],
  [  0,  0,  0,  0,  1,  0,  0,  0 ],
  [  0,  0,  0,  0,  0,  1,  0,  0 ],
  [  0,  0,  0,  0,  0,  0,  1,  0 ],
  [  0,  0,  0,  0,  0,  0,  0,  1 ],
  [  1,  0,  0,  0,  0,  0,  0,  0 ] ]
sqrt(p)*H=
[ [        1,        1,        1,        1,        1,        1,        1,        1 ],
  [        1,     E(8),     E(4),   E(8)^3,       -1,    -E(8),    -E(4),  -E(8)^3 ],
  [        1,     E(4),       -1,    -E(4),        1,     E(4),       -1,    -E(4) ],
  [        1,   E(8)^3,    -E(4),     E(8),       -1,  -E(8)^3,     E(4),    -E(8) ],
  [        1,       -1,        1,       -1,        1,       -1,        1,       -1 ],
  [        1,    -E(8),     E(4),  -E(8)^3,       -1,     E(8),    -E(4),   E(8)^3 ],
  [        1,    -E(4),       -1,     E(4),        1,    -E(4),       -1,     E(4) ],
  [        1,  -E(8)^3,    -E(4),    -E(8),       -1,   E(8)^3,     E(4),     E(8) ] ]
P=
  [       0,   E(16),       0,       0,       0,       0,       0,       0 ],
  [       0,       0,       0,  -E(16),       0,       0,       0,       0 ],
  [       0,       0,       0,       0,       0,  -E(16),       0,       0 ],
  [       0,       0,       0,       0,       0,       0,    E(4),       0 ],
  [       0,       0,       0,       0,       0,       0,       0,   E(16) ] ]
unknown
  • 2,405
