I trying to visualize qubits state after amplitude encoding.
I have the following code which takes the 8 feature [1/2, 1/2, 1/2, 1/2,1/2, 1/2,1/2,1/2] and encodes into 3 qubits.
I now get the output [0.35355339+0.j 0.35355339+0.j 0.35355339+0.j 0.35355339+0.j 0.35355339+0.j 0.35355339+0.j 0.35355339+0.j 0.35355339+0.j].
How to get individual qubits state from overall state, so I can visualize it using Qiskit.
import pennylane as qml
import numpy as np
dev = qml.device('default.qubit', wires=3)
@qml.qnode(dev) def circuit(f=None): qml.AmplitudeEmbedding(features=f, wires=range(3)) return qml.expval(qml.PauliZ(0))
feature_vector= [1/2, 1/2, 1/2, 1/2,1/2, 1/2,1/2,1/2]
normalized_feature_vector = feature_vector / np.linalg.norm(feature_vector) circuit(normalized_feature_vector)
print(dev.state)
glS
  • 27,510
  • 37
  • 125
Qiskit has some functions that can be used to visualize multi-qubit state. So, there is no need to get the state of individual qubits.
For example, you can use plot_state_qsphere
from qiskit.visualization import plot_state_qsphere
plot_state_qsphere(psi)
Here, psi is the state
psi = [0.35355339+0.j, 0.35355339+0.j, 0.35355339+0.j, 0.35355339+0.j, 0.35355339+0.j, 0.35355339+0.j, 0.35355339+0.j, 0.35355339+0.j]
The result:
For more details about Q-sphere see here
Another option is to use plot_bloch_multivector
from qiskit.visualization import plot_bloch_multivector
plot_bloch_multivector(psi)
The result:
Egretta.Thula
  • 11,986
  • 13
  • 34
Your qubits are in an equal superposition of all possible states.
$$ |\psi\rangle = \frac{1}{2\sqrt{2}}(|000\rangle+|001\rangle+|010\rangle+|011\rangle+|100\rangle+|101\rangle+|110\rangle+|111\rangle)\,, $$
$$ \therefore |\psi\rangle =\frac{1}{\sqrt{2}}(|0\rangle + |1\rangle) \otimes\frac{1}{\sqrt{2}}(|0\rangle + |1\rangle) \otimes\frac{1}{\sqrt{2}}(|0\rangle + |1\rangle) \,. $$
Hence, all your individual qubits are in the $|+\rangle$ state.
FDGod
  • 2,901
  • 31
