On page 26 of this paper (arXiv), it is written that in Knill's method of fault-tolerant error correction (FTEC), the output of the transversal bell measurement becomes $(P_m \otimes I) | \Phi_0 \rangle ^{\otimes n}$, and $P_m$, which is the necessary Pauli operator for teleportation, completes the teleportation by acting on the second ancilla block. However, I don't understand why $P_m$ completes the teleportation. I can understand why this would be the case in normal teleportation using three physical qubits, but I don't understand why it can be written in the same form in this case where we are performing transversal bell measurement using three logical qubits. Also, it seems that Knill's method can be applied not only to CSS codes, but also to others. So, does this mean that the transversal CNOT is not applying a logical CNOT?
Not quite sure how to convince you that this works. The whole point is creating a $[[n,1,d]]$ code is that the logical states, composed of $n$-qubits, operate in the same way as acting on a single (k=1) physical qubit. Of course, as long as you only apply logical operations on them. If you have multiple of those logical qubits, and you apply logical operations to them, they will still function as expected.
Perhaps you should write a simulation of this and see that it indeed works.
I haven't worked closely with Knill's method, but it seems that if you want it to be fault-tolerant, you will need the logical CNOT to be transversal. While CSS codes always have a transversal CNOT, non-CSS codes can have it as well with some caveats (see answers here).
- 1,933
- 7
- 17
