I am interested in the following Haar average over the unitary group
$D(x) = \int d\mathscr{U} ~(\mathscr{U})^{\otimes 2}(|\tilde{x}_{\mathscr{U}}\rangle\langle \tilde{x}_{\mathscr{U}}|)^{\otimes 2} (\mathscr{U}^\dagger)^{\otimes 2}$, where
$|\tilde{x}_{\mathscr{U}}\rangle = \frac{|x\rangle}{\sqrt{p_{\mathscr{U}}(x)}},$ $ p_{\mathscr{U}}(x) = \sum_i p_i ~\textrm{tr}(\mathscr{U}|x\rangle\langle x|\mathscr{U}^\dagger \rho_i),$ and $\{p_i, \rho_i\}$ is an ensemble of quantum states.
Now, following the standard approach, we consider
$V^{\otimes 2} D(x) (V^\dagger)^{\otimes 2} = \int d\mathscr{U} ~(\mathscr{U})^{\otimes 2}(|\tilde{x}_{V^\dagger\mathscr{U}}\rangle\langle \tilde{x}_{V^\dagger\mathscr{U}}|)^{\otimes 2} (\mathscr{U}^\dagger)^{\otimes 2}$, which follows from the invariance of Haar measure.
And so we find that
$(V^\dagger)^{\otimes 2} \otimes V^{\otimes 2}D(x)(V^\dagger)^{\otimes 2} \otimes V^{\otimes 2} = \int d\mathscr{U} ~(V^\dagger\mathscr{U})^{\otimes 2}(|\tilde{x}_{V^\dagger\mathscr{U}}\rangle\langle \tilde{x}_{V^\dagger\mathscr{U}}|)^{\otimes 2}((V^\dagger\mathscr{U})^{\dagger})^{\otimes 2}=D(x)$.
This means
$[D(x), (V^\dagger \otimes V)^{\otimes 2}] =0, ~~~~\forall V$. Operators that satisfy this relation are simply
$\mathbb{1}_4, ~\mathbb{1}_2 \otimes SWAP, ~SWAP \otimes \mathbb{1}_2, ~SWAP\otimes SWAP$. Taking linear combinations would allow us to work out $D(x)$.
I'm wondering if this is correct? And if this means that what we have is not a unitary design but a tensor product of two 2-designs. Note that $D(x)$ is not a homogenous polynomial in degrees of $(\mathscr{U}, \mathscr{U}^\dagger)$.
You have a syntactic mistake in your argument. The dimensions in the equation
$$(V^\dagger)^{\otimes 2} \otimes V^{\otimes 2}D(x)(V^\dagger)^{\otimes 2} \otimes V^{\otimes 2} = D(x) \,,$$
don't match. I am not sure what you intended to do, but you cannot conclude anything from this.
To address the other question independently, the vector space of linear operators which satisfy $[D, (V^\dagger \otimes V)^{\otimes 2}] =0, \forall V \in U(d)$ should be much larger. This subspace is isomorphic to the commutant of $V^{\otimes 4}$ and thus has dimension $4!=32$ (if $d\geq 4$). This follows by computing the following using suitable partial transposes: $$ \mathbb{E}_{V\sim U(d)} (V^\dagger \otimes V)^{\otimes 2} (\cdot) (V^\dagger \otimes V)^{\otimes 2\dagger} \simeq \mathbb{E}_{V} (V^\dagger \otimes V^\dagger \otimes V\otimes V)\otimes (V^\top \otimes V^\top \otimes \bar V\otimes \bar V) \\ \simeq \mathbb{E}_{V} (\bar V \otimes \bar V \otimes V\otimes V)\otimes (V \otimes V \otimes \bar V\otimes \bar V) \\ \simeq \mathbb{E}_{V} (V\otimes \bar V)^{\otimes 4} \simeq \mathbb{E}_{V} V^{\otimes 4}(\cdot) (V^{\otimes 4})^{\dagger} $$
Markus Heinrich
  • 5,652
  • 22
