As an example, consider the following Circuit defined by using the Python amazon-braket-sdk:
from braket.circuits import Circuit
bell = Circuit() bell.h(0) bell.cnot(0, 1)
How can I get the corresponding QASM code? If possible, I would like to do it directly, namely without going through any other intermediate library.
SimoneGasperini
  • 1,634
  • 18
You can get OpenQASM output from Braket circuits by using the following code:
from braket.circuits.serialization import IRType
bell = Circuit().h(0).cnot(0, 1) qasm_ir = bell.to_ir(IRType.OPENQASM) print(qasm_ir.source)
You can read more about to_ir here.
I hope that helps!
Milan-aws
  • 76
Amazon Braket does not have native support for converting circuits to OpenQASM 2. So besides implementing your own Python script, there's not currently a way to do this that does not involve going through an "intermediate" library.
As mentioned by @Callum in the comments, you could go through pytket + pytket-braket:
from pytket.qasm import circuit_to_qasm_str
from pytket.extensions.braket import braket_to_tk
circuit = # Amazon Braket circuit qasm_str = circuit_to_qasm_str(braket_to_tk(circuit))
You could also go through qBraid:
from qbraid import circuit_wrapper
circuit = # Amazon Braket circuit qasm_str = circuit_wrapper(circuit).transpile("qasm2")
Integrations through mitiq, amazon-braket-pennylane-plugin-python, or qiskit-braket-provider could also be equally if not more efficient than direct qasm conversions depending on your use-case.
Edit: Was not considering OpenQASM 3 conversions, which are supported! See answer above :)
ryanhill1
  • 2,623
  • 39
