In section VIII D of this paper, the authors describe a circuit synthesis procedure to find the unitary transformation (as a quantum circuit) which diagonalizes a set of mutually commuting pauli strings. The procedure is implemented here. I want to apply their codes in order to find such circuits, however I seem to miss something because the sets for which I wrote stabilizer matrices did not give correct circuits (I checked the circuits by turning them into unitaries and then conjugated a corresponding pauli string with it, i.e. $UAU^\dagger$ for some Pauli string $A$). I applied the same rules for writing the stabilizer matrices as they describe in section VIII C.
Regarding their example in the respective section, everything works fine: They check the set $\{ IYZ,ZZZ,XIX \}$ and the corresponding stabilizer matrix. The problem is when I want to find the transformation for other sets. For example, I try the following
sigmax = np.array([[0,1],[1,0]])
sigmay = np.array([[0,-1j,],[1j,0]])
sigmaz = np.array([[1,0],[0,-1]])
id2 = np.identity(2)
n=2 stabilizer_matrix = np.array([[0,1],[1,1],[1,0],[0,1]]) measurement_circuit = _get_measurement_circuit(stabilizer_matrix, n) #this is the function from the quotet github circ = measurement_circuit.circuit backend = qk.Aer.get_backend('unitary_simulator') job = qk.execute(circ, backend) result = job.result() U = result.get_unitary(circ, decimals=3) U_GC1 = np.array(U) print(U_GC1)
family_GC1 = [np.kron(sigmax, sigmaz), np.kron(sigmaz,sigmay), np.kron(sigmay, sigmax)] for op in family_GC1: print(np.transpose(U_GC1 @ op @ np.transpose(U_GC1.conj())))
The resulting outputs are not diagonal. Nevertheless, e.g. the set $\{ IX,XI,XX \}$ works. What is the problem here? Is the stabilizer matrix which i constructed by hand wrong somehow?
Juri V
  • 115
It seems that qiskit's unitary_simulator gives another result than doing it manually. For example, the unitary matrix given by the code above for the family $\{ XZ, ZY, YX \}$, the circuit is generated by:
n=2
measurement_circuit.circuit.draw()
and the output is:
q_0: ─■─┤ H ├─────
q_1: ─■─┤ S ├┤ H ├
c: 2/═════════════
Creating the unitary by hand as
CZ = np.array([[1,0,0,0],[0,1,0,0],[0,0,1,0],[0,0,0,-1]]) CNOT = np.array([[1,0,0,0],[0,1,0,0],[0,0,0,1],[0,0,1,0]]) SWAP = np.array([[1,0,0,0],[0,0,1,0],[0,1,0,0],[0,0,0,1]]) H = 1/np.sqrt(2)*np.array([[1,1],[1,-1]]) S = np.array([[1,0],[0,1j]])
U_XZ = np.kron(H,H) @ np.kron(id2, S) @ CZ #here is the unitary family_XZ = [np.kron(sigmax, sigmaz), np.kron(sigmaz,sigmay), np.kron(sigmay, sigmax)] for op in family_XZ: mat = U_XZ @ op @ np.transpose(U_XZ).conj() print(mat)
gives diagonalized matrices, as desired. The matrix looks like
U_XZ = np.kron(H,H) @ np.kron(id2, S) @ CZ =
[[ 0.5+0.j ,  0. +0.5j,  0.5+0.j ,  0. -0.5j],
 [ 0.5+0.j ,  0. -0.5j,  0.5+0.j ,  0. +0.5j],
 [ 0.5+0.j ,  0. +0.5j, -0.5+0.j ,  0. +0.5j],
 [ 0.5+0.j ,  0. -0.5j, -0.5+0.j ,  0. -0.5j]]
while the matrix given by the code in the question is:
[[ 0.5+0.j   0.5-0.j  -0. +0.5j -0. -0.5j]
 [ 0.5+0.j  -0.5+0.j  -0. +0.5j  0. +0.5j]
 [ 0.5+0.j   0.5-0.j   0. -0.5j  0. +0.5j]
 [ 0.5+0.j  -0.5+0.j   0. -0.5j -0. -0.5j]]
These are not the same. The latter does not properly diagonalize the family. This is because the unitary_simulator seems to reverse the ordering of the qubits. Reversing the ordering of the operators is therefore a workaround for this issue.
Juri V
  • 115
