Throughout, assume that $ n,K,d $ are integers such that an $ ((n,K,d)) $ code exists
Recall the quantum Hamming bound: For a non-degenerate ((n,K,d)) qubit code we must have $$ K(\sum_{j=0}^{\lfloor d/2 \rfloor} 3^j \binom{n}{j} ) \leq 2^n $$
If all codes with parameters $ ((n,K,d)) $ are degenerate then must the parameters $ ((n,K,d)) $ violate the quantum Hamming bound?
In other words, are there any parameter $ ((n,K,d)) $ that satisfy the quantum Hamming bound but it is still the case that all $ ((n,K,d)) $ codes are degenerate?
I think you've slightly mis-stated this: you need a $2^K$ instead of $K$.
So, it is true this bound applies rigorously to non-degenerate codes. That does not mean that all degenerate codes violate the bound. It just means that there could exist degenerate codes that violate it. In fact, most codes that you end up looking at typically do not violate the bound. For example, consider the Shor [[9,1,3]] code. This does not violate the bound.
You might want to check out this previous question: Violation of the Quantum Hamming bound
DaftWullie
  • 62,671
  • 55
  • 140
