I'm trying to install azure-quantum package with qiskit integration.
Following the azure tutorial (https://pypi.org/project/azure-quantum/) they say to use:
pip install --upgrade azure-quantum[qiskit]
in an environment with python 3.9 or higher and pip v.19.2 or higher.
I'm trying to install azure-quantum[qiskit] in a Conda environment equipped with python 3.9.16 and pip 22.3.1.
However, installing just azure-quantum with:
works fine, while if I specify the qiskit tag I get:
zsh: no matches found: azure-quantum[qiskit]
Any hint to solve the issue?
If you're on macOS the default shell zsh treats [ ] as regex instead of a string. To workaround this you can either escape the [ and ] or put quotes around it. In other words do this instead:
pip install --upgrade "azure-quantum[qiskit]"
or
pip install --upgrade azure-quantum\[qiskit\]
Matthew Treinish
  • 1,676
