Consider a finite subset $X\subset\mathbb{CP}^{d-1}$ of $d$-dimensional pure states. Following e.g. (Roy and Scott 2007), we say that $X$ is a complex projective $t$-design if $$\frac1{|X|}\sum_{x\in X} \mathbb{P}_x = \frac{\Pi_{\rm sym}^{(t)}}{\binom{d+t-1}{t}}, \qquad \mathbb{P}_x\equiv |x\rangle\!\langle x|,$$ where $\Pi_{\rm sym}^{(t)}$ is the projection onto the totally symmetric subspace of $(\mathbb{C}^d)^{\otimes t}$. Among other things, it is well-known that MUBs and SIC-POVMs are 2-designs, as per quant-ph/0502031, whereas stabiliser states are 3-designs, as per 1510.02767 and 1510.02619.
Perhaps the prototypical example of an MUB for a single qubit is given by the set of vectors $$X_{\rm MUB} =\{|0\rangle,|1\rangle, |0\rangle+|1\rangle,|0\rangle-|1\rangle,|0\rangle+i|1\rangle,|0\rangle-i|1\rangle\}.$$ It is not too hard to see that this is a 2-design, which more explicitly means that $$\frac16\sum_{x\in X_{\rm MUB}} \mathbb{P}_x\otimes \mathbb{P}_x = \frac{\Pi_{\rm sym}^{(t)}}{\binom{2+2-1}{2} } = \frac32 (I\otimes I+W),$$ where I used the explicit formula for the projection on the symmetric bipartite subspace, and $W$ is the swap operator.
Which brings me to my question. By playing numerically with these things, I found that $X_{\rm MUB}$ seems to be not only a 2-design, but a 3-design. That is, we have the stronger identity $$\frac16 \sum_{x\in X_{\rm MUB}} \mathbb{P}_x^{\otimes 3} = \frac14 \Pi_{\rm sym}^{(3)}.$$ Verifying this is equally pretty straightforward (unless I'm misunderstanding something here, which is possible). You can use for example the following Mathematica snippet
mubProjections = {
{1, 0}, {0, 1}, {1, 1}/Sqrt@2, {1, -1}/Sqrt@2, {1, I}/Sqrt@2, {1, -I}/Sqrt@2
} // Map[KroneckerProduct[#, Conjugate@#] &];
1/6 KroneckerProduct[#, #, #] & /@ mubProjections // Total // MatrixForm
and you can recognise the structure of the projection onto the symmetric subspace, which in this case looks like $$\Pi_{\rm sym}^{(3)} = \mathbb{P}_{000} + \mathbb{P}_{111} + \mathbb{P}\left(\frac{|100\rangle+|010\rangle+|001\rangle}{\sqrt3}\right) + \mathbb{P}\left(\frac{|101\rangle+|011\rangle+|110\rangle}{\sqrt3}\right).$$
Interestingly doing the same with 4 tensor products reveals that this MUB is not a 4-design, although it's not too far from being one.
Reading around, I didn't find any mention of MUBs being also 3-designs, though I also haven't found mentions of them not being so. By contrast, stabiliser states are known to be 3-designs but not 4-designs, as per the references above. I haven't checked other MUBs yet, so I'm not sure whether them being 3-designs holds in general (I'd expect not). Still, is there a good way to see why this MUB is a 3-design? Are there other MUBs that are so, and if so, is there a characterisation for the class of MUBs that are 3 designs?
