Elements of the (qubit) Clifford Hierarchy are unitary matrices. For a good definition of the Clifford Hierarchy see: Is there a closure property for the entire Clifford hierarchy?
While a complete structure theorem for the Clifford Hierarchy, $\mathcal{CH}$, is still lacking, can we prove that if $U\in \mathcal{CH}$ then $U^{\dagger}\in \mathcal{CH}$?
Cases:
$U$ is semi-Clifford
Semi-Clifford means that $U = C_L D C_R$ where $C_L, C_R$ are Clifford and $D$ is a diagonal gate in $\mathcal{CH}$.
Then, $U^\dagger = C_R^\dagger D^\dagger C_L^\dagger$. By [1] the diagonal gate in level k form a group so the inverse of $ D $ is also in level $ k $. Each level of the Clifford Hierarchy is closed under left and right multiplication by Clifford gates. So in this case $U^\dagger$ is even in the same level of $\mathcal{CH}$ as $U$.
$U$ is generalized semi-Clifford
Generalized semi-Clifford means that $U = C_L P D C_R$ where $C_L, C_R$ are Clifford, $D$ is a diagonal gate in $\mathcal{CH}$, and $P$ is a permutation (on states) in $\mathcal{CH}$. This was proven in [2].
In this case, $U^\dagger = C_R^\dagger D^\dagger P^\dagger C_L^\dagger = C_R^\dagger P^\dagger (P D^\dagger P^\dagger) C_L^\dagger$. And since the term in parentheses is a diagonal matrix with the same $2^k$ root-of-unity entries as $D$, it must be in $\mathcal{CH}$ (since $D$ is in $\mathcal{CH}$). We can also see that $U^\dagger$ must be generalized semi-Clifford and $U^\dagger$ is in $\mathcal{CH}$ iff $P^\dagger$ is in $\mathcal{CH}$. To complete the proof of this case I need to show that $P^\dagger$ is in $\mathcal{CH}$ which I currently do not know how to do.
General $U$
It is not known if all elements in $\mathcal{CH}$ are generalized semi-Clifford. Nevertheless, we may be able to prove (or disprove) this conjecture for general $U \in \mathcal{CH}$.
Jonas Anderson
  • 671
This partial answer breaks the question of the closure of the levels of the Clifford hierarchy under inversion into two parts: the easy question of closure under complex conjugation and the harder question of closure under transposition. It also offers a proof of the former and an informal argument for the latter.
Lemma 1 (Every level of the Clifford hierarchy is closed under complex conjugation)
For every $k\geqslant 1$, we have $$U\in\mathcal{C}^{(k)}\iff\overline{U}\in\mathcal{C}^{(k)}.\tag1$$ Proof. Equivalence $(1)$ is obviously true for every $U$ in the Pauli group $\mathcal{C}^{(1)}$. Assume that $(1)$ holds for $k$ and let $U\in\mathcal{C}^{(k+1)}$ and $P\in\mathcal{C}^{(1)}$. By definition $UPU^\dagger=V\in\mathcal{C}^{(k)}$. But then $$ \overline{U}P\overline{U}^\dagger=\pm \overline{U}\overline{P}\overline{U}^\dagger=\pm\overline{(UPU^\dagger)}=\pm\overline{V}\in\mathcal{C}^{(k)}\tag2 $$ so $\overline{U}\in\mathcal{C}^{(k+1)}$. $\square$
This immediately gives us
Corollary 2 (Symmetric subset of every level is closed under inversion)
If $U=e^{i\theta}U^T$ for some $\theta\in[0,2\pi)$, then $$U\in\mathcal{C}^{(k)}\iff U^\dagger\in\mathcal{C}^{(k)}\tag3$$ for every $k\geqslant 1$.
This provides a simple alternative route to closure under inversion for diagonal gates and extends it to gates such as $\sqrt{\text{iSWAP}}$ and various other swap gates. In fact, $(3)$ applies to every gate whose Pauli expansion consists of terms for which the parity of the number of $Y$ operators is the same (either all even or all odd). Unfortunately, this set does not include all permutations.
Conjecture 3 (Every level is closed under transposition)
For every $k\geqslant 1$, we have $$U\in\mathcal{C}^{(k)}\iff U^T\in\mathcal{C}^{(k)}\tag4.$$
Informal argument. Clifford hierarchy arises as the set of gates that admit fault-tolerant implementation using gate teleportation, see page $3$ in "Quantum teleportation is a universal computational primitive". The protocol is summarized in figure $2$ of the paper
The protocol consists of two stages. In the first stage, we prepare $n$ Bell pairs $|\Phi^n\rangle$ and apply the desired gate $U\in\mathcal{C}^{(k)}$ to one half of the Bell pairs obtaining $$ |\Psi^n_U\rangle=(I\otimes U)|\Psi^n\rangle.\tag5 $$ In the second stage, we perform Bell measurements $B$ on the input state $|\alpha\rangle$ and the other half of the state created in $(5)$ and finally apply corrections conditioned on the measurement outcomes using $R'^\dagger_{xz}\in\mathcal{C}^{(k-1)}$.
Now, it is easy to check that $$ |\Psi^n_U\rangle=(U^T\otimes I)|\Psi^n\rangle.\tag6 $$ Thus, two changes are needed in the protocol above to effect $U^T$ rather than $U$. First, we can apply $U$ on the middle qubit rather than the bottom qubit (or alternatively apply $U^T$ to the bottom qubit). Second, replace the $R'_{xz}=UR_{xz}U^\dagger$ correction with the $R''_{xz}=U^TR_{xz}\overline{U}$ correction.
We know that $R'_{xz}\in\mathcal{C}^{(k-1)}$, but we don't know whether $R''_{xz}\in\mathcal{C}^{(k-1)}$. However, one of the changes to the protocol necessary to effect $U^T$ rather than $U$ is operationally very simple: apply $U$ on a different qubit. One might then suspect that the associated update to the correction isn't too complicated and in particular, the correction stays in $\mathcal{C}^{(k-1)}$. I don't know how to prove this at the moment, though. $\square$
Lemma 1 and Conjecture 3 combine to give us
Corollary 4 (Every level is closed under inversion)
For every $k\geqslant 1$, we have $$U\in\mathcal{C}^{(k)}\iff U^\dagger\in\mathcal{C}^{(k)}\tag7.$$
Adam Zalcman
  • 25,260
  • 40
  • 95
